I've pushed my OC a bit further, memtest stable, and PCMark stable. Windows detects everything fine and dandy, I went to reboot back into Gentoo so I could fold again, and see if its really stable..but Gentoo is detecting only one core. Here is my kern.log file (from syslog-ng).
The intersting part:
The rest:
Jan 27 07:29:55 localhost Memory: 1023016k/1047424k available (4238k kernel code, 24016k reserved, 2142k data, 324k init)
Jan 27 07:29:55 localhost Calibrating delay using timer specific routine.. 6869.39 BogoMIPS (lpj=13738783)
Jan 27 07:29:55 localhost Mount-cache hash table entries: 256
Jan 27 07:29:55 localhost CPU: L1 I cache: 32K, L1 D cache: 32K
Jan 27 07:29:55 localhost CPU: L2 cache: 2048K
Jan 27 07:29:55 localhost CPU 0/0 -> Node 0
Jan 27 07:29:55 localhost using mwait in idle threads.
Jan 27 07:29:55 localhost CPU: Physical Processor ID: 0
Jan 27 07:29:55 localhost CPU: Processor Core ID: 0
Jan 27 07:29:55 localhost CPU0: Thermal monitoring enabled (TM2)
Jan 27 07:29:55 localhost SMP alternatives: switching to UP code
Jan 27 07:29:55 localhost ACPI: Core revision 20060707
Jan 27 07:29:55 localhost Using local APIC timer interrupts.
Jan 27 07:29:55 localhost result 30624968
Jan 27 07:29:55 localhost Detected 30.624 MHz APIC timer.
Jan 27 07:29:55 localhost SMP alternatives: switching to SMP code
Jan 27 07:29:55 localhost Booting processor 1/2 APIC 0x1
Jan 27 07:29:55 localhost Not responding.
Jan 27 07:29:55 localhost Inquiring remote APIC #1...
Jan 27 07:29:55 localhost ... APIC #1 ID: failed
Jan 27 07:29:55 localhost ... APIC #1 VERSION: failed
Jan 27 07:29:55 localhost ... APIC #1 SPIV: failed
Jan 27 07:29:55 localhost Brought up 1 CPUs
The rest:
Code:
Jan 27 07:29:55 localhost Linux version 2.6.20-gentoo-r8 (root@localhost) (gcc version 4.1.2 (Gentoo 4.1.2 p1.0.1)) #6 SMP Sun Dec 2 14:35:26 EST 2007
Jan 27 07:29:55 localhost Command line: root=/dev/sda7
Jan 27 07:29:55 localhost BIOS-provided physical RAM map:
Jan 27 07:29:55 localhost BIOS-e820: 0000000000000000 - 000000000009e800 (usable)
Jan 27 07:29:55 localhost BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
Jan 27 07:29:55 localhost BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Jan 27 07:29:55 localhost BIOS-e820: 0000000000100000 - 000000003fee0000 (usable)
Jan 27 07:29:55 localhost BIOS-e820: 000000003fee0000 - 000000003fee3000 (ACPI NVS)
Jan 27 07:29:55 localhost BIOS-e820: 000000003fee3000 - 000000003fef0000 (ACPI data)
Jan 27 07:29:55 localhost BIOS-e820: 000000003fef0000 - 000000003ff00000 (reserved)
Jan 27 07:29:55 localhost BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
Jan 27 07:29:55 localhost BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Jan 27 07:29:55 localhost Entering add_active_range(0, 0, 158) 0 entries of 3200 used
Jan 27 07:29:55 localhost Entering add_active_range(0, 256, 261856) 1 entries of 3200 used
Jan 27 07:29:55 localhost end_pfn_map = 1048576
Jan 27 07:29:55 localhost DMI 2.4 present.
Jan 27 07:29:55 localhost ACPI: RSDP (v000 GBT ) @ 0x00000000000f6c30
Jan 27 07:29:55 localhost ACPI: RSDT (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee3040
Jan 27 07:29:55 localhost ACPI: FADT (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee30c0
Jan 27 07:29:55 localhost ACPI: HPET (v001 GBT GBTUACPI 0x42302e31 GBTU 0x00000098) @ 0x000000003fee7e00
Jan 27 07:29:55 localhost ACPI: MCFG (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee7e80
Jan 27 07:29:55 localhost ACPI: MADT (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee7d00
Jan 27 07:29:55 localhost ACPI: DSDT (v001 GBT GBTUACPI 0x00001000 MSFT 0x0100000c) @ 0x0000000000000000
Jan 27 07:29:55 localhost No NUMA configuration found
Jan 27 07:29:55 localhost Faking a node at 0000000000000000-000000003fee0000
Jan 27 07:29:55 localhost Bootmem setup node 0 0000000000000000-000000003fee0000
Jan 27 07:29:55 localhost Zone PFN ranges:
Jan 27 07:29:55 localhost DMA 0 -> 4096
Jan 27 07:29:55 localhost DMA32 4096 -> 1048576
Jan 27 07:29:55 localhost Normal 1048576 -> 1048576
Jan 27 07:29:55 localhost early_node_map[2] active PFN ranges
Jan 27 07:29:55 localhost 0: 0 -> 158
Jan 27 07:29:55 localhost 0: 256 -> 261856
Jan 27 07:29:55 localhost On node 0 totalpages: 261758
Jan 27 07:29:55 localhost DMA zone: 56 pages used for memmap
Jan 27 07:29:55 localhost DMA zone: 1917 pages reserved
Jan 27 07:29:55 localhost DMA zone: 2025 pages, LIFO batch:0
Jan 27 07:29:55 localhost DMA32 zone: 3524 pages used for memmap
Jan 27 07:29:55 localhost DMA32 zone: 254236 pages, LIFO batch:31
Jan 27 07:29:55 localhost Normal zone: 0 pages used for memmap
Jan 27 07:29:55 localhost ACPI: PM-Timer IO Port: 0x408
Jan 27 07:29:55 localhost ACPI: Local APIC address 0xfee00000
Jan 27 07:29:55 localhost ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Jan 27 07:29:55 localhost Processor #0 (Bootup-CPU)
Jan 27 07:29:55 localhost ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Jan 27 07:29:55 localhost Processor #1
Jan 27 07:29:55 localhost ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
Jan 27 07:29:55 localhost ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
Jan 27 07:29:55 localhost ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
Jan 27 07:29:55 localhost ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
Jan 27 07:29:55 localhost ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
Jan 27 07:29:55 localhost ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
Jan 27 07:29:55 localhost ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jan 27 07:29:55 localhost IOAPIC[0]: apic_id 2, address 0xfec00000, GSI 0-23
Jan 27 07:29:55 localhost ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jan 27 07:29:55 localhost ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jan 27 07:29:55 localhost ACPI: IRQ0 used by override.
Jan 27 07:29:55 localhost ACPI: IRQ2 used by override.
Jan 27 07:29:55 localhost ACPI: IRQ9 used by override.
Jan 27 07:29:55 localhost Setting APIC routing to physical flat
Jan 27 07:29:55 localhost ACPI: HPET id: 0x8086a201 base: 0xfed00000
Jan 27 07:29:55 localhost Using ACPI (MADT) for SMP configuration information
Jan 27 07:29:55 localhost Nosave address range: 000000000009e000 - 00000000000a0000
Jan 27 07:29:55 localhost Nosave address range: 00000000000a0000 - 00000000000f0000
Jan 27 07:29:55 localhost Nosave address range: 00000000000f0000 - 0000000000100000
Jan 27 07:29:55 localhost Allocating PCI resources starting at 40000000 (gap: 3ff00000:b0100000)
Jan 27 07:29:55 localhost SMP: Allowing 4 CPUs, 2 hotplug CPUs
Jan 27 07:29:55 localhost PERCPU: Allocating 36800 bytes of per cpu data
Jan 27 07:29:55 localhost Built 1 zonelists. Total pages: 256261
Jan 27 07:29:55 localhost Kernel command line: root=/dev/sda7
Jan 27 07:29:55 localhost Initializing CPU#0
Jan 27 07:29:55 localhost PID hash table entries: 4096 (order: 12, 32768 bytes)
Jan 27 07:29:55 localhost Console: colour VGA+ 80x25
Jan 27 07:29:55 localhost Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jan 27 07:29:55 localhost Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Jan 27 07:29:55 localhost Checking aperture...
Jan 27 07:29:55 localhost testing NMI watchdog ... OK.
Jan 27 07:29:55 localhost time.c: Using 14.318180 MHz WALL HPET GTOD HPET/TSC timer.
Jan 27 07:29:55 localhost time.c: Detected 3429.996 MHz processor.
Jan 27 07:29:55 localhost NET: Registered protocol family 16
Jan 27 07:29:55 localhost ACPI: bus type pci registered
Jan 27 07:29:55 localhost PCI: Using MMCONFIG at f0000000
Jan 27 07:29:55 localhost ACPI: Interpreter enabled
Jan 27 07:29:55 localhost ACPI: Using IOAPIC for interrupt routing
Jan 27 07:29:55 localhost ACPI: PCI Root Bridge [PCI0] (0000:00)
Jan 27 07:29:55 localhost PCI: Probing PCI hardware (bus 00)
Jan 27 07:29:55 localhost Boot video device is 0000:01:00.0
Jan 27 07:29:55 localhost PCI: Transparent bridge - 0000:00:1e.0
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX4._PRT]
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 14 *15)
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Jan 27 07:29:55 localhost ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 9 10 11 12 *14 15)
Jan 27 07:29:55 localhost Linux Plug and Play Support v0.97 (c) Adam Belay
Jan 27 07:29:55 localhost pnp: PnP ACPI init
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0A03
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0C02
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0200
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0103
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0B00
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0800
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0C04
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0700
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0501
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0400
Jan 27 07:29:55 localhost pnp: ACPI device : hid PNP0C01
Jan 27 07:29:55 localhost pnp: ACPI device : hid INT0800
Jan 27 07:29:55 localhost pnp: PnP ACPI: found 14 devices
Jan 27 07:29:55 localhost SCSI subsystem initialized
Jan 27 07:29:55 localhost libata version 2.00 loaded.
Jan 27 07:29:55 localhost usbcore: registered new interface driver usbfs
Jan 27 07:29:55 localhost usbcore: registered new interface driver hub
Jan 27 07:29:55 localhost usbcore: registered new device driver usb
Jan 27 07:29:55 localhost PCI: Using ACPI for IRQ routing
Jan 27 07:29:55 localhost PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Jan 27 07:29:55 localhost PCI: Cannot allocate resource region 2 of device 0000:03:00.0
Jan 27 07:29:55 localhost PCI: Cannot allocate resource region 3 of device 0000:03:00.0
Jan 27 07:29:55 localhost hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
Jan 27 07:29:55 localhost hpet0: 4 64-bit timers, 14318180 Hz
Jan 27 07:29:55 localhost PCI-GART: No AMD northbridge found.
Jan 27 07:29:55 localhost pnp: the driver 'system' has been registered
Jan 27 07:29:55 localhost pnp: match found with the PnP device '00:01' and the driver 'system'
Jan 27 07:29:55 localhost pnp: match found with the PnP device '00:0a' and the driver 'system'
Jan 27 07:29:55 localhost pnp: 00:0a: ioport range 0x400-0x4bf could not be reserved
Jan 27 07:29:55 localhost pnp: match found with the PnP device '00:0b' and the driver 'system'
Jan 27 07:29:55 localhost pnp: match found with the PnP device '00:0c' and the driver 'system'
Jan 27 07:29:55 localhost PCI: Bridge: 0000:00:01.0
Jan 27 07:29:55 localhost IO window: a000-afff
Jan 27 07:29:55 localhost MEM window: f4000000-f6ffffff
Jan 27 07:29:55 localhost PREFETCH window: e0000000-efffffff
Jan 27 07:29:55 localhost PCI: Bridge: 0000:00:1c.0
Jan 27 07:29:55 localhost IO window: 9000-9fff
Jan 27 07:29:55 localhost MEM window: disabled.
Jan 27 07:29:55 localhost PREFETCH window: disabled.
Jan 27 07:29:55 localhost PCI: Bridge: 0000:00:1c.3
Jan 27 07:29:55 localhost IO window: b000-bfff
Jan 27 07:29:55 localhost MEM window: f9000000-f90fffff
Jan 27 07:29:55 localhost PCI: Bridge: 0000:00:1c.4
Jan 27 07:29:55 localhost IO window: c000-cfff
Jan 27 07:29:55 localhost MEM window: f7000000-f8ffffff
Jan 27 07:29:55 localhost PREFETCH window: 40000000-400fffff
Jan 27 07:29:55 localhost PCI: Bridge: 0000:00:1e.0
Jan 27 07:29:55 localhost IO window: d000-dfff
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:01.0 to 64
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1c.0 to 64
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1c.3[D] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1c.3 to 64
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1c.4[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1c.4 to 64
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1e.0 to 64
Jan 27 07:29:55 localhost NET: Registered protocol family 2
Jan 27 07:29:55 localhost IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
Jan 27 07:29:55 localhost TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
Jan 27 07:29:55 localhost TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jan 27 07:29:55 localhost TCP: Hash tables configured (established 131072 bind 65536)
Jan 27 07:29:55 localhost TCP reno registered
Jan 27 07:29:55 localhost IA-32 Microcode Update Driver: v1.14a <[email protected]>
Jan 27 07:29:55 localhost Total HugeTLB memory allocated, 0
Jan 27 07:29:55 localhost Installing knfsd (copyright (C) 1996 [email protected]).
Jan 27 07:29:55 localhost NTFS driver 2.1.28 [Flags: R/O].
Jan 27 07:29:55 localhost JFS: nTxBlock = 7992, nTxLock = 63938
Jan 27 07:29:55 localhost SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
Jan 27 07:29:55 localhost SGI XFS Quota Management subsystem
Jan 27 07:29:55 localhost io scheduler noop registered
Jan 27 07:29:55 localhost io scheduler deadline registered
Jan 27 07:29:55 localhost io scheduler cfq registered (default)
Jan 27 07:29:55 localhost assign_interrupt_mode Found MSI capability
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:01.0:pcie00]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:01.0:pcie03]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.0:pcie00]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.0:pcie02]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.0:pcie03]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.3:pcie00]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.3:pcie02]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.3:pcie03]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.4:pcie00]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.4:pcie02]
Jan 27 07:29:55 localhost Allocate Port Service[0000:00:1c.4:pcie03]
Jan 27 07:29:55 localhost Initializing CPU#1
Jan 27 07:29:55 localhost Unable to handle kernel NULL pointer dereference at 0000000000000000 RIP:
Jan 27 07:29:55 localhost [<ffffffff80259ee1>] get_page_from_freelist+0x179/0x473
Jan 27 07:29:55 localhost PGD 0
Jan 27 07:29:55 localhost Oops: 0000 [1] SMP
Jan 27 07:29:55 localhost CPU 1
Jan 27 07:29:55 localhost Modules linked in:
Jan 27 07:29:55 localhost Pid: 0, comm: swapper Not tainted 2.6.20-gentoo-r8 #6
Jan 27 07:29:55 localhost RIP: 0010:[<ffffffff80259ee1>] [<ffffffff80259ee1>] get_page_from_freelist+0x179/0x473
Jan 27 07:29:55 localhost RSP: 0018:ffff81003f04fda8 EFLAGS: 00010046
Jan 27 07:29:55 localhost RAX: 0000000000000001 RBX: 0000000000000000 RCX: 0000000000000000
Jan 27 07:29:55 localhost RDX: 0000000000000000 RSI: 00000000000004e7 RDI: ffff81000000b3c0
Jan 27 07:29:55 localhost RBP: 0000000000000046 R08: 0000000000000000 R09: 000000000003cfc9
Jan 27 07:29:55 localhost R10: 0000000000000000 R11: 0000000000000001 R12: ffff81000000b3c0
Jan 27 07:29:55 localhost R13: 0000000000000000 R14: 0000000000000000 R15: ffff81000000caa0
Jan 27 07:29:55 localhost FS: 0000000000000000(0000) GS:ffff81003f00cd40(0000) knlGS:0000000000000000
Jan 27 07:29:55 localhost CS: 0010 DS: 0018 ES: 0018 CR0: 0000000080050033
Jan 27 07:29:55 localhost CR2: 0000000000000000 CR3: 0000000000201000 CR4: 00000000000000a0
Jan 27 07:29:55 localhost Process swapper (pid: 0, threadinfo ffff81003f04e000, task ffff81003f022080)
Jan 27 07:29:55 localhost Stack: 0000004400000000 0002002000000000 ffff81000000caa8 0000000100000000
Jan 27 07:29:55 localhost 0000000000000000 00000000802324df 0000000000000000 0000000000000001
Jan 27 07:29:55 localhost ffff81003f04fdf8 0000000000000000 0000000000000020 ffff81000000caa0
Jan 27 07:29:55 localhost Call Trace:
Jan 27 07:29:55 localhost [<ffffffff8025a340>] __alloc_pages+0x61/0x2b5
Jan 27 07:29:55 localhost [<ffffffff8026ec4a>] alloc_page_interleave+0x40/0x83
Jan 27 07:29:55 localhost [<ffffffff80259d0f>] __get_free_pages+0xe/0x33
Jan 27 07:29:55 localhost [<ffffffff802102da>] cpu_init+0x129/0x30b
Jan 27 07:29:55 localhost [<ffffffff802180e2>] start_secondary+0x13/0x479
Jan 27 07:29:55 localhost Code: 83 3b 00 75 6d 48 63 43 08 49 8d bc 24 50 01 00 00 45 31 ed
Jan 27 07:29:55 localhost RIP [<ffffffff80259ee1>] get_page_from_freelist+0x179/0x473
Jan 27 07:29:55 localhost RSP <ffff81003f04fda8>
Jan 27 07:29:55 localhost <0>Kernel panic - not syncing: Attempted to kill the idle task!
Jan 27 07:29:55 localhost <6>Real Time Clock Driver v1.12ac
Jan 27 07:29:55 localhost hpet_resources: 0xfed00000 is busy
Jan 27 07:29:55 localhost Linux agpgart interface v0.101 (c) Dave Jones
Jan 27 07:29:55 localhost input: Power Button (FF) as /class/input/input0
Jan 27 07:29:55 localhost ACPI: Power Button (FF) [PWRF]
Jan 27 07:29:55 localhost input: Power Button (CM) as /class/input/input1
Jan 27 07:29:55 localhost ACPI: Power Button (CM) [PWRB]
Jan 27 07:29:55 localhost ACPI: Processor [CPU0] (supports 8 throttling states)
Jan 27 07:29:55 localhost ACPI Exception (acpi_processor-0677): AE_NOT_FOUND, Processor Device is not present [20060707]
Jan 27 07:29:55 localhost Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Jan 27 07:29:55 localhost serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jan 27 07:29:55 localhost pnp: the driver 'serial' has been registered
Jan 27 07:29:55 localhost pnp: match found with the PnP device '00:08' and the driver 'serial'
Jan 27 07:29:55 localhost 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jan 27 07:29:55 localhost Floppy drive(s): fd0 is 1.44M
Jan 27 07:29:55 localhost FDC 0 is a post-1991 82077
Jan 27 07:29:55 localhost RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Jan 27 07:29:55 localhost loop: loaded (max 8 devices)
Jan 27 07:29:55 localhost Intel(R) PRO/1000 Network Driver - version 7.3.15-k2
Jan 27 07:29:55 localhost Copyright (c) 1999-2006 Intel Corporation.
Jan 27 07:29:55 localhost e100: Intel(R) PRO/100 Network Driver, 3.5.17-k2-NAPI
Jan 27 07:29:55 localhost e100: Copyright(c) 1999-2006 Intel Corporation
Jan 27 07:29:55 localhost forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.59.
Jan 27 07:29:55 localhost tun: Universal TUN/TAP device driver, 1.6
Jan 27 07:29:55 localhost tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Jan 27 07:29:55 localhost r8169 Gigabit Ethernet driver 2.2LK loaded
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:04:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:04:00.0 to 64
Jan 27 07:29:55 localhost eth0: RTL8168b/8111b at 0xffffc20000006000, 00:1a:4d:47:2a:6b, IRQ 16
Jan 27 07:29:55 localhost netconsole: not configured, aborting
Jan 27 07:29:55 localhost Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Jan 27 07:29:55 localhost ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Jan 27 07:29:55 localhost JMB363: IDE controller at PCI slot 0000:03:00.0
Jan 27 07:29:55 localhost PCI: Device 0000:03:00.0 not available because of resource collisions
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:29:55 localhost JMB363: BIOS configuration fixed.
Jan 27 07:29:55 localhost JMB363: chipset revision 2
Jan 27 07:29:55 localhost JMB363: 100% native mode on irq 19
Jan 27 07:29:55 localhost JMB363: dma_base is invalid
Jan 27 07:29:55 localhost ide0: JMB363 Bus-Master DMA disabled (BIOS)
Jan 27 07:29:55 localhost ide1: JMB363 Bus-Master DMA disabled (BIOS)
Jan 27 07:29:55 localhost Probing IDE interface ide0...
Jan 27 07:29:55 localhost Probing IDE interface ide1...
Jan 27 07:29:55 localhost JMB363: IDE controller at PCI slot 0000:03:00.1
Jan 27 07:29:55 localhost PCI: Enabling device 0000:03:00.1 (0000 -> 0001)
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:03:00.1[B] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost JMB363: 100% native mode on irq 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:03:00.1 to 64
Jan 27 07:29:55 localhost ide2: BM-DMA at 0xb400-0xb407, BIOS settings: hde:pio, hdf:DMA
Jan 27 07:29:55 localhost ide3: BM-DMA at 0xb408-0xb40f, BIOS settings: hdg:pio, hdh:pio
Jan 27 07:29:55 localhost Probing IDE interface ide2...
Jan 27 07:29:55 localhost hdf: 16X8 DVD DUAL, ATAPI CD/DVD-ROM drive
Jan 27 07:29:55 localhost hdf: hw_config=0000
Jan 27 07:29:55 localhost ide2 at 0xb000-0xb007,0xb102 on irq 16
Jan 27 07:29:55 localhost Probing IDE interface ide3...
Jan 27 07:29:55 localhost hdf: ATAPI 126X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache<6>hdf: hw_config=0000
Jan 27 07:29:55 localhost , UDMA(66)
Jan 27 07:29:55 localhost Uniform CD-ROM driver Revision: 3.20
Jan 27 07:29:55 localhost megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
Jan 27 07:29:55 localhost megaraid: 2.20.4.9 (Release Date: Sun Jul 16 12:27:22 EST 2006)
Jan 27 07:29:55 localhost megasas: 00.00.03.05 Mon Oct 02 11:21:32 PDT 2006
Jan 27 07:29:55 localhost ahci 0000:00:1f.2: version 2.0
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1f.2 to 64
Jan 27 07:29:55 localhost ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
Jan 27 07:29:55 localhost ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pmp pio slum part
Jan 27 07:29:55 localhost ata1: SATA max UDMA/133 cmd 0xFFFFC20000012100 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:29:55 localhost ata2: SATA max UDMA/133 cmd 0xFFFFC20000012180 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:29:55 localhost ata3: SATA max UDMA/133 cmd 0xFFFFC20000012200 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:29:55 localhost ata4: SATA max UDMA/133 cmd 0xFFFFC20000012280 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:29:55 localhost ata5: SATA max UDMA/133 cmd 0xFFFFC20000012300 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:29:55 localhost ata6: SATA max UDMA/133 cmd 0xFFFFC20000012380 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:29:55 localhost scsi0 : ahci
Jan 27 07:29:55 localhost ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jan 27 07:29:55 localhost ata1.00: ATA-7, max UDMA/133, 488395055 sectors: LBA48 NCQ (depth 31/32)
Jan 27 07:29:55 localhost ata1.00: ata1: dev 0 multi count 0
Jan 27 07:29:55 localhost ata1.00: configured for UDMA/133
Jan 27 07:29:55 localhost scsi1 : ahci
Jan 27 07:29:55 localhost ata2: SATA link down (SStatus 0 SControl 300)
Jan 27 07:29:55 localhost scsi2 : ahci
Jan 27 07:29:55 localhost ata3: SATA link down (SStatus 0 SControl 300)
Jan 27 07:29:55 localhost scsi3 : ahci
Jan 27 07:29:55 localhost ata4: SATA link down (SStatus 0 SControl 300)
Jan 27 07:29:55 localhost scsi4 : ahci
Jan 27 07:29:55 localhost ata5: SATA link down (SStatus 0 SControl 300)
Jan 27 07:29:55 localhost scsi5 : ahci
Jan 27 07:29:55 localhost ata6: SATA link down (SStatus 0 SControl 300)
Jan 27 07:29:55 localhost scsi 0:0:0:0: Direct-Access ATA HDT722525DLA380 V44O PQ: 0 ANSI: 5
Jan 27 07:29:55 localhost SCSI device sda: 488395055 512-byte hdwr sectors (250058 MB)
Jan 27 07:29:55 localhost sda: Write Protect is off
Jan 27 07:29:55 localhost sda: Mode Sense: 00 3a 00 00
Jan 27 07:29:55 localhost SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 27 07:29:55 localhost sda: sda1 sda2 < sda5 sda6 sda7 sda8 > sda3 sda4
Jan 27 07:29:55 localhost sd 0:0:0:0: Attached scsi disk sda
Jan 27 07:29:55 localhost sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 27 07:29:55 localhost Fusion MPT base driver 3.04.03
Jan 27 07:29:55 localhost Copyright (c) 1999-2007 LSI Logic Corporation
Jan 27 07:29:55 localhost Fusion MPT SPI Host driver 3.04.03
Jan 27 07:29:55 localhost Fusion MPT SAS Host driver 3.04.03
Jan 27 07:29:55 localhost ieee1394: raw1394: /dev/raw1394 device initialized
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1a.7 to 64
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1a.7: EHCI Host Controller
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Jan 27 07:29:55 localhost PCI: cache line size of 32 is not supported by device 0000:00:1a.7
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9100000
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jan 27 07:29:55 localhost usb usb1: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 1-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 1-0:1.0: 6 ports detected
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1d.7 to 64
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1d.7: EHCI Host Controller
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
Jan 27 07:29:55 localhost PCI: cache line size of 32 is not supported by device 0000:00:1d.7
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9101000
Jan 27 07:29:55 localhost ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jan 27 07:29:55 localhost usb usb2: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 2-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 2-0:1.0: 6 ports detected
Jan 27 07:29:55 localhost ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
Jan 27 07:29:55 localhost USB Universal Host Controller Interface driver v3.0
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1a.0 to 64
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.0: UHCI Host Controller
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000e000
Jan 27 07:29:55 localhost usb usb3: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 3-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 3-0:1.0: 2 ports detected
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 21
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1a.1 to 64
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.1: UHCI Host Controller
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000e100
Jan 27 07:29:55 localhost usb usb4: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 4-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 4-0:1.0: 2 ports detected
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1a.2[C] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1a.2 to 64
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.2: UHCI Host Controller
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000e500
Jan 27 07:29:55 localhost usb usb5: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 5-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 5-0:1.0: 2 ports detected
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1d.0 to 64
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.0: UHCI Host Controller
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000e200
Jan 27 07:29:55 localhost usb usb6: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 6-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 6-0:1.0: 2 ports detected
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1d.1 to 64
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.1: UHCI Host Controller
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e300
Jan 27 07:29:55 localhost usb usb7: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 7-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 7-0:1.0: 2 ports detected
Jan 27 07:29:55 localhost usb 1-4: new high speed USB device using ehci_hcd and address 4
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:00:1d.2 to 64
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.2: UHCI Host Controller
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
Jan 27 07:29:55 localhost uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e400
Jan 27 07:29:55 localhost usb usb8: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost hub 8-0:1.0: USB hub found
Jan 27 07:29:55 localhost hub 8-0:1.0: 2 ports detected
Jan 27 07:29:55 localhost usb 1-4: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost usb 3-2: new low speed USB device using uhci_hcd and address 2
Jan 27 07:29:55 localhost usb 3-2: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost usb 4-1: new full speed USB device using uhci_hcd and address 2
Jan 27 07:29:55 localhost usb 4-1: configuration #1 chosen from 1 choice
Jan 27 07:29:55 localhost drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x04A9 pid 0x10A2
Jan 27 07:29:55 localhost usbcore: registered new interface driver usblp
Jan 27 07:29:55 localhost drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Jan 27 07:29:55 localhost Initializing USB Mass Storage driver...
Jan 27 07:29:55 localhost usbcore: registered new interface driver usb-storage
Jan 27 07:29:55 localhost USB Mass Storage support registered.
Jan 27 07:29:55 localhost HID device not claimed by input or hiddev
Jan 27 07:29:55 localhost input: Logitech USB Receiver as /class/input/input2
Jan 27 07:29:55 localhost input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.1-1
Jan 27 07:29:55 localhost input: Logitech USB Receiver as /class/input/input3
Jan 27 07:29:55 localhost input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.1-1
Jan 27 07:29:55 localhost usbcore: registered new interface driver usbhid
Jan 27 07:29:55 localhost drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Jan 27 07:29:55 localhost pnp: the driver 'i8042 kbd' has been registered
Jan 27 07:29:55 localhost pnp: the driver 'i8042 aux' has been registered
Jan 27 07:29:55 localhost pnp: the driver 'i8042 kbd' has been unregistered
Jan 27 07:29:55 localhost pnp: the driver 'i8042 aux' has been unregistered
Jan 27 07:29:55 localhost PNP: No PS/2 controller found. Probing ports directly.
Jan 27 07:29:55 localhost serio: i8042 KBD port at 0x60,0x64 irq 1
Jan 27 07:29:55 localhost serio: i8042 AUX port at 0x60,0x64 irq 12
Jan 27 07:29:55 localhost mice: PS/2 mouse device common for all mice
Jan 27 07:29:55 localhost device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: [email protected]
Jan 27 07:29:55 localhost Advanced Linux Sound Architecture Driver Version 1.0.14rc1 (Tue Jan 09 09:56:17 2007 UTC).
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:05:02.0[A] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:29:55 localhost Audigy2 value: Special config.
Jan 27 07:29:55 localhost ALSA device list:
Jan 27 07:29:55 localhost #0: Audigy 2 Value [SB0400] (rev.0, serial:0x10011102) at 0xd000, irq 18
Jan 27 07:29:55 localhost oprofile: using NMI interrupt.
Jan 27 07:29:55 localhost IPv4 over IPv4 tunneling driver
Jan 27 07:29:55 localhost TCP cubic registered
Jan 27 07:29:55 localhost NET: Registered protocol family 10
Jan 27 07:29:55 localhost IPv6 over IPv4 tunneling driver
Jan 27 07:29:55 localhost NET: Registered protocol family 17
Jan 27 07:29:55 localhost 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Jan 27 07:29:55 localhost All bugs added by David S. Miller <[email protected]>
Jan 27 07:29:55 localhost ACPI: (supports S0 S3 S4 S5)
Jan 27 07:29:55 localhost ReiserFS: sda7: found reiserfs format "3.6" with standard journal
Jan 27 07:29:55 localhost ReiserFS: sda7: using ordered data mode
Jan 27 07:29:55 localhost ReiserFS: sda7: journal params: device sda7, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Jan 27 07:29:55 localhost ReiserFS: sda7: checking transaction log (sda7)
Jan 27 07:29:55 localhost ReiserFS: sda7: journal-1153: found in header: first_unflushed_offset 1216, last_flushed_trans_id 1616970
Jan 27 07:29:55 localhost ReiserFS: sda7: journal-1006: found valid transaction start offset 1216, len 5 id 1615752
Jan 27 07:29:55 localhost ReiserFS: sda7: journal-1206: Starting replay from offset 1216, trans_id 1616971
Jan 27 07:29:55 localhost ReiserFS: sda7: journal-1037: journal_read_transaction, offset 1216, len 5 mount_id 221
Jan 27 07:29:55 localhost ReiserFS: sda7: journal-1039: journal_read_trans skipping because 1216 is too old
Jan 27 07:29:55 localhost ReiserFS: sda7: journal-1299: Setting newest_mount_id to 224
Jan 27 07:29:55 localhost ReiserFS: sda7: Using r5 hash to sort names
Jan 27 07:29:55 localhost VFS: Mounted root (reiserfs filesystem) readonly.
Jan 27 07:29:55 localhost Freeing unused kernel memory: 324k freed
Jan 27 07:29:55 localhost i2c /dev entries driver
Jan 27 07:29:55 localhost nvidia: module license 'NVIDIA' taints kernel.
Jan 27 07:29:55 localhost ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:29:55 localhost PCI: Setting latency timer of device 0000:01:00.0 to 64
Jan 27 07:29:55 localhost NVRM: loading NVIDIA UNIX x86_64 Kernel Module 100.14.19 Wed Sep 12 14:08:38 PDT 2007
Jan 27 07:29:55 localhost kjournald starting. Commit interval 5 seconds
Jan 27 07:29:55 localhost EXT3 FS on sda6, internal journal
Jan 27 07:29:55 localhost EXT3-fs: mounted filesystem with ordered data mode.
Jan 27 07:29:55 localhost EXT3 FS on sda4, internal journal
Jan 27 07:29:55 localhost fuse init (API version 7.8)
Jan 27 07:29:55 localhost fuse distribution version: 2.7.0
Jan 27 07:29:55 localhost Adding 2441840k swap on /dev/sda5. Priority:-1 extents:1 across:2441840k
Jan 27 07:29:55 localhost r8169: eth0: link up
Jan 27 07:29:55 localhost device eth0 entered promiscuous mode
Jan 27 07:29:55 localhost br0: port 1(eth0) entering learning state
Jan 27 07:29:55 localhost br0: topology change detected, propagating
Jan 27 07:29:55 localhost br0: port 1(eth0) entering forwarding state
Jan 27 07:29:55 localhost eth0: no IPv6 routers present
Jan 27 07:29:55 localhost br0: no IPv6 routers present
Jan 27 07:29:55 localhost ata1: D2H reg with I during NCQ, this message won't be printed again
Jan 27 07:29:55 localhost hdf: cdrom_pc_intr: The drive appears confused (ireason = 0x01). Trying to recover by ending request.
Jan 27 07:30:37 localhost hdf: cdrom_pc_intr: The drive appears confused (ireason = 0x01). Trying to recover by ending request.
Jan 27 07:32:00 localhost nfsd: last server has exited
Jan 27 07:32:00 localhost nfsd: unexporting all filesystems
Jan 27 07:32:01 localhost br0: port 1(eth0) entering disabled state
Jan 27 07:32:01 localhost device eth0 left promiscuous mode
Jan 27 07:33:02 localhost Linux version 2.6.20-gentoo-r8 (root@localhost) (gcc version 4.1.2 (Gentoo 4.1.2 p1.0.1)) #6 SMP Sun Dec 2 14:35:26 EST 2007
Jan 27 07:33:02 localhost Command line: root=/dev/sda7
Jan 27 07:33:02 localhost BIOS-provided physical RAM map:
Jan 27 07:33:02 localhost BIOS-e820: 0000000000000000 - 000000000009e800 (usable)
Jan 27 07:33:02 localhost BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
Jan 27 07:33:02 localhost BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Jan 27 07:33:02 localhost BIOS-e820: 0000000000100000 - 000000003fee0000 (usable)
Jan 27 07:33:02 localhost BIOS-e820: 000000003fee0000 - 000000003fee3000 (ACPI NVS)
Jan 27 07:33:02 localhost BIOS-e820: 000000003fee3000 - 000000003fef0000 (ACPI data)
Jan 27 07:33:02 localhost BIOS-e820: 000000003fef0000 - 000000003ff00000 (reserved)
Jan 27 07:33:02 localhost BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
Jan 27 07:33:02 localhost BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Jan 27 07:33:02 localhost Entering add_active_range(0, 0, 158) 0 entries of 3200 used
Jan 27 07:33:02 localhost Entering add_active_range(0, 256, 261856) 1 entries of 3200 used
Jan 27 07:33:02 localhost end_pfn_map = 1048576
Jan 27 07:33:02 localhost DMI 2.4 present.
Jan 27 07:33:02 localhost ACPI: RSDP (v000 GBT ) @ 0x00000000000f6c30
Jan 27 07:33:02 localhost ACPI: RSDT (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee3040
Jan 27 07:33:02 localhost ACPI: FADT (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee30c0
Jan 27 07:33:02 localhost ACPI: HPET (v001 GBT GBTUACPI 0x42302e31 GBTU 0x00000098) @ 0x000000003fee7e00
Jan 27 07:33:02 localhost ACPI: MCFG (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee7e80
Jan 27 07:33:02 localhost ACPI: MADT (v001 GBT GBTUACPI 0x42302e31 GBTU 0x01010101) @ 0x000000003fee7d00
Jan 27 07:33:02 localhost ACPI: DSDT (v001 GBT GBTUACPI 0x00001000 MSFT 0x0100000c) @ 0x0000000000000000
Jan 27 07:33:02 localhost No NUMA configuration found
Jan 27 07:33:02 localhost Faking a node at 0000000000000000-000000003fee0000
Jan 27 07:33:02 localhost Bootmem setup node 0 0000000000000000-000000003fee0000
Jan 27 07:33:02 localhost Zone PFN ranges:
Jan 27 07:33:02 localhost DMA 0 -> 4096
Jan 27 07:33:02 localhost DMA32 4096 -> 1048576
Jan 27 07:33:02 localhost Normal 1048576 -> 1048576
Jan 27 07:33:02 localhost early_node_map[2] active PFN ranges
Jan 27 07:33:02 localhost 0: 0 -> 158
Jan 27 07:33:02 localhost 0: 256 -> 261856
Jan 27 07:33:02 localhost On node 0 totalpages: 261758
Jan 27 07:33:02 localhost DMA zone: 56 pages used for memmap
Jan 27 07:33:02 localhost DMA zone: 1917 pages reserved
Jan 27 07:33:02 localhost DMA zone: 2025 pages, LIFO batch:0
Jan 27 07:33:02 localhost DMA32 zone: 3524 pages used for memmap
Jan 27 07:33:02 localhost DMA32 zone: 254236 pages, LIFO batch:31
Jan 27 07:33:02 localhost Normal zone: 0 pages used for memmap
Jan 27 07:33:02 localhost ACPI: PM-Timer IO Port: 0x408
Jan 27 07:33:02 localhost ACPI: Local APIC address 0xfee00000
Jan 27 07:33:02 localhost ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Jan 27 07:33:02 localhost Processor #0 (Bootup-CPU)
Jan 27 07:33:02 localhost ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Jan 27 07:33:02 localhost Processor #1
Jan 27 07:33:02 localhost ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
Jan 27 07:33:02 localhost ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
Jan 27 07:33:02 localhost ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
Jan 27 07:33:02 localhost ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
Jan 27 07:33:02 localhost ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
Jan 27 07:33:02 localhost ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
Jan 27 07:33:02 localhost ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Jan 27 07:33:02 localhost IOAPIC[0]: apic_id 2, address 0xfec00000, GSI 0-23
Jan 27 07:33:02 localhost ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jan 27 07:33:02 localhost ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jan 27 07:33:02 localhost ACPI: IRQ0 used by override.
Jan 27 07:33:02 localhost ACPI: IRQ2 used by override.
Jan 27 07:33:02 localhost ACPI: IRQ9 used by override.
Jan 27 07:33:02 localhost Setting APIC routing to physical flat
Jan 27 07:33:02 localhost ACPI: HPET id: 0x8086a201 base: 0xfed00000
Jan 27 07:33:02 localhost Using ACPI (MADT) for SMP configuration information
Jan 27 07:33:02 localhost Nosave address range: 000000000009e000 - 00000000000a0000
Jan 27 07:33:02 localhost Nosave address range: 00000000000a0000 - 00000000000f0000
Jan 27 07:33:02 localhost Nosave address range: 00000000000f0000 - 0000000000100000
Jan 27 07:33:02 localhost Allocating PCI resources starting at 40000000 (gap: 3ff00000:b0100000)
Jan 27 07:33:02 localhost SMP: Allowing 4 CPUs, 2 hotplug CPUs
Jan 27 07:33:02 localhost PERCPU: Allocating 36800 bytes of per cpu data
Jan 27 07:33:02 localhost Built 1 zonelists. Total pages: 256261
Jan 27 07:33:02 localhost Kernel command line: root=/dev/sda7
Jan 27 07:33:02 localhost Initializing CPU#0
Jan 27 07:33:02 localhost PID hash table entries: 4096 (order: 12, 32768 bytes)
Jan 27 07:33:02 localhost Console: colour VGA+ 80x25
Jan 27 07:33:02 localhost Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Jan 27 07:33:02 localhost Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Jan 27 07:33:02 localhost Checking aperture...
Jan 27 07:33:02 localhost Memory: 1023016k/1047424k available (4238k kernel code, 24016k reserved, 2142k data, 324k init)
Jan 27 07:33:02 localhost Calibrating delay using timer specific routine.. 6869.33 BogoMIPS (lpj=13738675)
Jan 27 07:33:02 localhost Mount-cache hash table entries: 256
Jan 27 07:33:02 localhost CPU: L1 I cache: 32K, L1 D cache: 32K
Jan 27 07:33:02 localhost CPU: L2 cache: 2048K
Jan 27 07:33:02 localhost CPU 0/0 -> Node 0
Jan 27 07:33:02 localhost using mwait in idle threads.
Jan 27 07:33:02 localhost CPU: Physical Processor ID: 0
Jan 27 07:33:02 localhost CPU: Processor Core ID: 0
Jan 27 07:33:02 localhost CPU0: Thermal monitoring enabled (TM2)
Jan 27 07:33:02 localhost SMP alternatives: switching to UP code
Jan 27 07:33:02 localhost ACPI: Core revision 20060707
Jan 27 07:33:02 localhost Using local APIC timer interrupts.
Jan 27 07:33:02 localhost result 30625028
Jan 27 07:33:02 localhost Detected 30.625 MHz APIC timer.
Jan 27 07:33:02 localhost SMP alternatives: switching to SMP code
Jan 27 07:33:02 localhost Booting processor 1/2 APIC 0x1
Jan 27 07:33:02 localhost Not responding.
Jan 27 07:33:02 localhost Inquiring remote APIC #1...
Jan 27 07:33:02 localhost ... APIC #1 ID: failed
Jan 27 07:33:02 localhost ... APIC #1 VERSION: failed
Jan 27 07:33:02 localhost ... APIC #1 SPIV: failed
Jan 27 07:33:02 localhost Brought up 1 CPUs
Jan 27 07:33:02 localhost testing NMI watchdog ... OK.
Jan 27 07:33:02 localhost time.c: Using 14.318180 MHz WALL HPET GTOD HPET/TSC timer.
Jan 27 07:33:02 localhost time.c: Detected 3430.002 MHz processor.
Jan 27 07:33:02 localhost NET: Registered protocol family 16
Jan 27 07:33:02 localhost ACPI: bus type pci registered
Jan 27 07:33:02 localhost PCI: Using MMCONFIG at f0000000
Jan 27 07:33:02 localhost ACPI: Interpreter enabled
Jan 27 07:33:02 localhost ACPI: Using IOAPIC for interrupt routing
Jan 27 07:33:02 localhost ACPI: PCI Root Bridge [PCI0] (0000:00)
Jan 27 07:33:02 localhost PCI: Probing PCI hardware (bus 00)
Jan 27 07:33:02 localhost Boot video device is 0000:01:00.0
Jan 27 07:33:02 localhost PCI: Transparent bridge - 0000:00:1e.0
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX4._PRT]
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 14 *15)
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
Jan 27 07:33:02 localhost ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 9 10 11 12 *14 15)
Jan 27 07:33:02 localhost Linux Plug and Play Support v0.97 (c) Adam Belay
Jan 27 07:33:02 localhost pnp: PnP ACPI init
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0A03
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0C02
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0200
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0103
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0B00
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0800
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0C04
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0700
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0501
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0400
Jan 27 07:33:02 localhost pnp: ACPI device : hid PNP0C01
Jan 27 07:33:02 localhost pnp: ACPI device : hid INT0800
Jan 27 07:33:02 localhost pnp: PnP ACPI: found 14 devices
Jan 27 07:33:02 localhost SCSI subsystem initialized
Jan 27 07:33:02 localhost libata version 2.00 loaded.
Jan 27 07:33:02 localhost usbcore: registered new interface driver usbfs
Jan 27 07:33:02 localhost usbcore: registered new interface driver hub
Jan 27 07:33:02 localhost usbcore: registered new device driver usb
Jan 27 07:33:02 localhost PCI: Using ACPI for IRQ routing
Jan 27 07:33:02 localhost PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Jan 27 07:33:02 localhost PCI: Cannot allocate resource region 2 of device 0000:03:00.0
Jan 27 07:33:02 localhost PCI: Cannot allocate resource region 3 of device 0000:03:00.0
Jan 27 07:33:02 localhost hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
Jan 27 07:33:02 localhost hpet0: 4 64-bit timers, 14318180 Hz
Jan 27 07:33:02 localhost PCI-GART: No AMD northbridge found.
Jan 27 07:33:02 localhost pnp: the driver 'system' has been registered
Jan 27 07:33:02 localhost pnp: match found with the PnP device '00:01' and the driver 'system'
Jan 27 07:33:02 localhost pnp: match found with the PnP device '00:0a' and the driver 'system'
Jan 27 07:33:02 localhost pnp: 00:0a: ioport range 0x400-0x4bf could not be reserved
Jan 27 07:33:02 localhost pnp: match found with the PnP device '00:0b' and the driver 'system'
Jan 27 07:33:02 localhost pnp: match found with the PnP device '00:0c' and the driver 'system'
Jan 27 07:33:02 localhost PCI: Bridge: 0000:00:01.0
Jan 27 07:33:02 localhost IO window: a000-afff
Jan 27 07:33:02 localhost MEM window: f4000000-f6ffffff
Jan 27 07:33:02 localhost PREFETCH window: e0000000-efffffff
Jan 27 07:33:02 localhost PCI: Bridge: 0000:00:1c.0
Jan 27 07:33:02 localhost IO window: 9000-9fff
Jan 27 07:33:02 localhost MEM window: disabled.
Jan 27 07:33:02 localhost PREFETCH window: disabled.
Jan 27 07:33:02 localhost PCI: Bridge: 0000:00:1c.3
Jan 27 07:33:02 localhost IO window: b000-bfff
Jan 27 07:33:02 localhost MEM window: f9000000-f90fffff
Jan 27 07:33:02 localhost PCI: Bridge: 0000:00:1c.4
Jan 27 07:33:02 localhost IO window: c000-cfff
Jan 27 07:33:02 localhost MEM window: f7000000-f8ffffff
Jan 27 07:33:02 localhost PREFETCH window: 40000000-400fffff
Jan 27 07:33:02 localhost PCI: Bridge: 0000:00:1e.0
Jan 27 07:33:02 localhost IO window: d000-dfff
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:01.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:01.0 to 64
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1c.0 to 64
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1c.3[D] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1c.3 to 64
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1c.4[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1c.4 to 64
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1e.0 to 64
Jan 27 07:33:02 localhost NET: Registered protocol family 2
Jan 27 07:33:02 localhost IP route cache hash table entries: 32768 (order: 6, 262144 bytes)
Jan 27 07:33:02 localhost TCP established hash table entries: 131072 (order: 9, 2097152 bytes)
Jan 27 07:33:02 localhost TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Jan 27 07:33:02 localhost TCP: Hash tables configured (established 131072 bind 65536)
Jan 27 07:33:02 localhost TCP reno registered
Jan 27 07:33:02 localhost IA-32 Microcode Update Driver: v1.14a <[email protected]>
Jan 27 07:33:02 localhost Total HugeTLB memory allocated, 0
Jan 27 07:33:02 localhost Installing knfsd (copyright (C) 1996 [email protected]).
Jan 27 07:33:02 localhost NTFS driver 2.1.28 [Flags: R/O].
Jan 27 07:33:02 localhost JFS: nTxBlock = 7992, nTxLock = 63938
Jan 27 07:33:02 localhost SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
Jan 27 07:33:02 localhost SGI XFS Quota Management subsystem
Jan 27 07:33:02 localhost io scheduler noop registered
Jan 27 07:33:02 localhost io scheduler deadline registered
Jan 27 07:33:02 localhost io scheduler cfq registered (default)
Jan 27 07:33:02 localhost assign_interrupt_mode Found MSI capability
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:01.0:pcie00]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:01.0:pcie03]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.0:pcie00]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.0:pcie02]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.0:pcie03]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.3:pcie00]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.3:pcie02]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.3:pcie03]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.4:pcie00]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.4:pcie02]
Jan 27 07:33:02 localhost Allocate Port Service[0000:00:1c.4:pcie03]
Jan 27 07:33:02 localhost Initializing CPU#1
Jan 27 07:33:02 localhost Unable to handle kernel NULL pointer dereference at 0000000000000000 RIP:
Jan 27 07:33:02 localhost [<ffffffff80259ee1>] get_page_from_freelist+0x179/0x473
Jan 27 07:33:02 localhost PGD 0
Jan 27 07:33:02 localhost Oops: 0000 [1] SMP
Jan 27 07:33:02 localhost CPU 1
Jan 27 07:33:02 localhost Modules linked in:
Jan 27 07:33:02 localhost Pid: 0, comm: swapper Not tainted 2.6.20-gentoo-r8 #6
Jan 27 07:33:02 localhost RIP: 0010:[<ffffffff80259ee1>] [<ffffffff80259ee1>] get_page_from_freelist+0x179/0x473
Jan 27 07:33:02 localhost RSP: 0018:ffff81003f04fda8 EFLAGS: 00010046
Jan 27 07:33:02 localhost RAX: 0000000000000001 RBX: 0000000000000000 RCX: 0000000000000000
Jan 27 07:33:02 localhost RDX: 0000000000000000 RSI: 00000000000004e7 RDI: ffff81000000b3c0
Jan 27 07:33:02 localhost RBP: 0000000000000046 R08: 0000000000000000 R09: 000000000003d091
Jan 27 07:33:02 localhost R10: 0000000000000000 R11: 0000000000000001 R12: ffff81000000b3c0
Jan 27 07:33:02 localhost R13: 0000000000000000 R14: 0000000000000000 R15: ffff81000000caa0
Jan 27 07:33:02 localhost FS: 0000000000000000(0000) GS:ffff81003f00cd40(0000) knlGS:0000000000000000
Jan 27 07:33:02 localhost CS: 0010 DS: 0018 ES: 0018 CR0: 0000000080050033
Jan 27 07:33:02 localhost CR2: 0000000000000000 CR3: 0000000000201000 CR4: 00000000000000a0
Jan 27 07:33:02 localhost Process swapper (pid: 0, threadinfo ffff81003f04e000, task ffff81003f022080)
Jan 27 07:33:02 localhost Stack: 0000004400000000 0002002000000000 ffff81000000caa8 0000000100000000
Jan 27 07:33:02 localhost 0000000000000000 00000000802324df 0000000000000000 0000000000000001
Jan 27 07:33:02 localhost ffff81003f04fdf8 0000000000000000 0000000000000020 ffff81000000caa0
Jan 27 07:33:02 localhost Call Trace:
Jan 27 07:33:02 localhost [<ffffffff8025a340>] __alloc_pages+0x61/0x2b5
Jan 27 07:33:02 localhost [<ffffffff8026ec4a>] alloc_page_interleave+0x40/0x83
Jan 27 07:33:02 localhost [<ffffffff80259d0f>] __get_free_pages+0xe/0x33
Jan 27 07:33:02 localhost [<ffffffff802102da>] cpu_init+0x129/0x30b
Jan 27 07:33:02 localhost [<ffffffff802180e2>] start_secondary+0x13/0x479
Jan 27 07:33:02 localhost Code: 83 3b 00 75 6d 48 63 43 08 49 8d bc 24 50 01 00 00 45 31 ed
Jan 27 07:33:02 localhost RIP [<ffffffff80259ee1>] get_page_from_freelist+0x179/0x473
Jan 27 07:33:02 localhost RSP <ffff81003f04fda8>
Jan 27 07:33:02 localhost <0>Kernel panic - not syncing: Attempted to kill the idle task!
Jan 27 07:33:02 localhost <6>Real Time Clock Driver v1.12ac
Jan 27 07:33:02 localhost hpet_resources: 0xfed00000 is busy
Jan 27 07:33:02 localhost Linux agpgart interface v0.101 (c) Dave Jones
Jan 27 07:33:02 localhost input: Power Button (FF) as /class/input/input0
Jan 27 07:33:02 localhost ACPI: Power Button (FF) [PWRF]
Jan 27 07:33:02 localhost input: Power Button (CM) as /class/input/input1
Jan 27 07:33:02 localhost ACPI: Power Button (CM) [PWRB]
Jan 27 07:33:02 localhost ACPI: Processor [CPU0] (supports 8 throttling states)
Jan 27 07:33:02 localhost ACPI Exception (acpi_processor-0677): AE_NOT_FOUND, Processor Device is not present [20060707]
Jan 27 07:33:02 localhost Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Jan 27 07:33:02 localhost serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jan 27 07:33:02 localhost pnp: the driver 'serial' has been registered
Jan 27 07:33:02 localhost pnp: match found with the PnP device '00:08' and the driver 'serial'
Jan 27 07:33:02 localhost 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jan 27 07:33:02 localhost Floppy drive(s): fd0 is 1.44M
Jan 27 07:33:02 localhost FDC 0 is a post-1991 82077
Jan 27 07:33:02 localhost RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
Jan 27 07:33:02 localhost loop: loaded (max 8 devices)
Jan 27 07:33:02 localhost Intel(R) PRO/1000 Network Driver - version 7.3.15-k2
Jan 27 07:33:02 localhost Copyright (c) 1999-2006 Intel Corporation.
Jan 27 07:33:02 localhost e100: Intel(R) PRO/100 Network Driver, 3.5.17-k2-NAPI
Jan 27 07:33:02 localhost e100: Copyright(c) 1999-2006 Intel Corporation
Jan 27 07:33:02 localhost forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.59.
Jan 27 07:33:02 localhost tun: Universal TUN/TAP device driver, 1.6
Jan 27 07:33:02 localhost tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Jan 27 07:33:02 localhost r8169 Gigabit Ethernet driver 2.2LK loaded
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:04:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:04:00.0 to 64
Jan 27 07:33:02 localhost eth0: RTL8168b/8111b at 0xffffc20000006000, 00:1a:4d:47:2a:6b, IRQ 16
Jan 27 07:33:02 localhost netconsole: not configured, aborting
Jan 27 07:33:02 localhost Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Jan 27 07:33:02 localhost ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Jan 27 07:33:02 localhost JMB363: IDE controller at PCI slot 0000:03:00.0
Jan 27 07:33:02 localhost PCI: Device 0000:03:00.0 not available because of resource collisions
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:03:00.0[A] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:33:02 localhost JMB363: BIOS configuration fixed.
Jan 27 07:33:02 localhost JMB363: chipset revision 2
Jan 27 07:33:02 localhost JMB363: 100% native mode on irq 19
Jan 27 07:33:02 localhost JMB363: dma_base is invalid
Jan 27 07:33:02 localhost ide0: JMB363 Bus-Master DMA disabled (BIOS)
Jan 27 07:33:02 localhost ide1: JMB363 Bus-Master DMA disabled (BIOS)
Jan 27 07:33:02 localhost Probing IDE interface ide0...
Jan 27 07:33:02 localhost Probing IDE interface ide1...
Jan 27 07:33:02 localhost JMB363: IDE controller at PCI slot 0000:03:00.1
Jan 27 07:33:02 localhost PCI: Enabling device 0000:03:00.1 (0000 -> 0001)
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:03:00.1[B] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost JMB363: 100% native mode on irq 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:03:00.1 to 64
Jan 27 07:33:02 localhost ide2: BM-DMA at 0xb400-0xb407, BIOS settings: hde:pio, hdf:DMA
Jan 27 07:33:02 localhost ide3: BM-DMA at 0xb408-0xb40f, BIOS settings: hdg:pio, hdh:pio
Jan 27 07:33:02 localhost Probing IDE interface ide2...
Jan 27 07:33:02 localhost hdf: 16X8 DVD DUAL, ATAPI CD/DVD-ROM drive
Jan 27 07:33:02 localhost hdf: hw_config=0000
Jan 27 07:33:02 localhost ide2 at 0xb000-0xb007,0xb102 on irq 16
Jan 27 07:33:02 localhost Probing IDE interface ide3...
Jan 27 07:33:02 localhost hdf: ATAPI 126X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache<6>hdf: hw_config=0000
Jan 27 07:33:02 localhost , UDMA(66)
Jan 27 07:33:02 localhost Uniform CD-ROM driver Revision: 3.20
Jan 27 07:33:02 localhost megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
Jan 27 07:33:02 localhost megaraid: 2.20.4.9 (Release Date: Sun Jul 16 12:27:22 EST 2006)
Jan 27 07:33:02 localhost megasas: 00.00.03.05 Mon Oct 02 11:21:32 PDT 2006
Jan 27 07:33:02 localhost ahci 0000:00:1f.2: version 2.0
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1f.2 to 64
Jan 27 07:33:02 localhost ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
Jan 27 07:33:02 localhost ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo pmp pio slum part
Jan 27 07:33:02 localhost ata1: SATA max UDMA/133 cmd 0xFFFFC20000012100 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:33:02 localhost ata2: SATA max UDMA/133 cmd 0xFFFFC20000012180 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:33:02 localhost ata3: SATA max UDMA/133 cmd 0xFFFFC20000012200 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:33:02 localhost ata4: SATA max UDMA/133 cmd 0xFFFFC20000012280 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:33:02 localhost ata5: SATA max UDMA/133 cmd 0xFFFFC20000012300 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:33:02 localhost ata6: SATA max UDMA/133 cmd 0xFFFFC20000012380 ctl 0x0 bmdma 0x0 irq 1275
Jan 27 07:33:02 localhost scsi0 : ahci
Jan 27 07:33:02 localhost ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Jan 27 07:33:02 localhost ata1.00: ATA-7, max UDMA/133, 488395055 sectors: LBA48 NCQ (depth 31/32)
Jan 27 07:33:02 localhost ata1.00: ata1: dev 0 multi count 0
Jan 27 07:33:02 localhost ata1.00: configured for UDMA/133
Jan 27 07:33:02 localhost scsi1 : ahci
Jan 27 07:33:02 localhost ata2: SATA link down (SStatus 0 SControl 300)
Jan 27 07:33:02 localhost scsi2 : ahci
Jan 27 07:33:02 localhost ata3: SATA link down (SStatus 0 SControl 300)
Jan 27 07:33:02 localhost scsi3 : ahci
Jan 27 07:33:02 localhost ata4: SATA link down (SStatus 0 SControl 300)
Jan 27 07:33:02 localhost scsi4 : ahci
Jan 27 07:33:02 localhost ata5: SATA link down (SStatus 0 SControl 300)
Jan 27 07:33:02 localhost scsi5 : ahci
Jan 27 07:33:02 localhost ata6: SATA link down (SStatus 0 SControl 300)
Jan 27 07:33:02 localhost scsi 0:0:0:0: Direct-Access ATA HDT722525DLA380 V44O PQ: 0 ANSI: 5
Jan 27 07:33:02 localhost SCSI device sda: 488395055 512-byte hdwr sectors (250058 MB)
Jan 27 07:33:02 localhost sda: Write Protect is off
Jan 27 07:33:02 localhost sda: Mode Sense: 00 3a 00 00
Jan 27 07:33:02 localhost SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jan 27 07:33:02 localhost sda: sda1 sda2 < sda5 sda6 sda7 sda8 > sda3 sda4
Jan 27 07:33:02 localhost sd 0:0:0:0: Attached scsi disk sda
Jan 27 07:33:02 localhost sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 27 07:33:02 localhost Fusion MPT base driver 3.04.03
Jan 27 07:33:02 localhost Copyright (c) 1999-2007 LSI Logic Corporation
Jan 27 07:33:02 localhost Fusion MPT SPI Host driver 3.04.03
Jan 27 07:33:02 localhost Fusion MPT SAS Host driver 3.04.03
Jan 27 07:33:02 localhost ieee1394: raw1394: /dev/raw1394 device initialized
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1a.7[C] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1a.7 to 64
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1a.7: EHCI Host Controller
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
Jan 27 07:33:02 localhost PCI: cache line size of 32 is not supported by device 0000:00:1a.7
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1a.7: irq 18, io mem 0xf9100000
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jan 27 07:33:02 localhost usb usb1: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 1-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 1-0:1.0: 6 ports detected
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 23
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1d.7 to 64
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1d.7: EHCI Host Controller
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
Jan 27 07:33:02 localhost PCI: cache line size of 32 is not supported by device 0000:00:1d.7
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1d.7: irq 23, io mem 0xf9101000
Jan 27 07:33:02 localhost ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Jan 27 07:33:02 localhost usb usb2: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 2-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 2-0:1.0: 6 ports detected
Jan 27 07:33:02 localhost ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
Jan 27 07:33:02 localhost USB Universal Host Controller Interface driver v3.0
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1a.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1a.0 to 64
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.0: UHCI Host Controller
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000e000
Jan 27 07:33:02 localhost usb usb3: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 3-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 3-0:1.0: 2 ports detected
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1a.1[B] -> GSI 21 (level, low) -> IRQ 21
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1a.1 to 64
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.1: UHCI Host Controller
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.1: irq 21, io base 0x0000e100
Jan 27 07:33:02 localhost usb usb4: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 4-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 4-0:1.0: 2 ports detected
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1a.2[C] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1a.2 to 64
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.2: UHCI Host Controller
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1a.2: irq 18, io base 0x0000e500
Jan 27 07:33:02 localhost usb usb5: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 5-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 5-0:1.0: 2 ports detected
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 23
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1d.0 to 64
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.0: UHCI Host Controller
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000e200
Jan 27 07:33:02 localhost usb usb6: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 6-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 6-0:1.0: 2 ports detected
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1d.1 to 64
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.1: UHCI Host Controller
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e300
Jan 27 07:33:02 localhost usb usb7: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 7-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 7-0:1.0: 2 ports detected
Jan 27 07:33:02 localhost usb 1-4: new high speed USB device using ehci_hcd and address 4
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:00:1d.2 to 64
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.2: UHCI Host Controller
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
Jan 27 07:33:02 localhost uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000e400
Jan 27 07:33:02 localhost usb usb8: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost hub 8-0:1.0: USB hub found
Jan 27 07:33:02 localhost hub 8-0:1.0: 2 ports detected
Jan 27 07:33:02 localhost usb 1-4: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost usb 3-2: new low speed USB device using uhci_hcd and address 2
Jan 27 07:33:02 localhost usb 3-2: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost usb 4-1: new full speed USB device using uhci_hcd and address 2
Jan 27 07:33:02 localhost usb 4-1: configuration #1 chosen from 1 choice
Jan 27 07:33:02 localhost drivers/usb/class/usblp.c: usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x04A9 pid 0x10A2
Jan 27 07:33:02 localhost usbcore: registered new interface driver usblp
Jan 27 07:33:02 localhost drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Jan 27 07:33:02 localhost Initializing USB Mass Storage driver...
Jan 27 07:33:02 localhost usbcore: registered new interface driver usb-storage
Jan 27 07:33:02 localhost USB Mass Storage support registered.
Jan 27 07:33:02 localhost HID device not claimed by input or hiddev
Jan 27 07:33:02 localhost input: Logitech USB Receiver as /class/input/input2
Jan 27 07:33:02 localhost input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.1-1
Jan 27 07:33:02 localhost input: Logitech USB Receiver as /class/input/input3
Jan 27 07:33:02 localhost input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:1a.1-1
Jan 27 07:33:02 localhost usbcore: registered new interface driver usbhid
Jan 27 07:33:02 localhost drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Jan 27 07:33:02 localhost pnp: the driver 'i8042 kbd' has been registered
Jan 27 07:33:02 localhost pnp: the driver 'i8042 aux' has been registered
Jan 27 07:33:02 localhost pnp: the driver 'i8042 kbd' has been unregistered
Jan 27 07:33:02 localhost pnp: the driver 'i8042 aux' has been unregistered
Jan 27 07:33:02 localhost PNP: No PS/2 controller found. Probing ports directly.
Jan 27 07:33:02 localhost serio: i8042 KBD port at 0x60,0x64 irq 1
Jan 27 07:33:02 localhost serio: i8042 AUX port at 0x60,0x64 irq 12
Jan 27 07:33:02 localhost mice: PS/2 mouse device common for all mice
Jan 27 07:33:02 localhost device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: [email protected]
Jan 27 07:33:02 localhost Advanced Linux Sound Architecture Driver Version 1.0.14rc1 (Tue Jan 09 09:56:17 2007 UTC).
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:05:02.0[A] -> GSI 18 (level, low) -> IRQ 18
Jan 27 07:33:02 localhost Audigy2 value: Special config.
Jan 27 07:33:02 localhost ALSA device list:
Jan 27 07:33:02 localhost #0: Audigy 2 Value [SB0400] (rev.0, serial:0x10011102) at 0xd000, irq 18
Jan 27 07:33:02 localhost oprofile: using NMI interrupt.
Jan 27 07:33:02 localhost IPv4 over IPv4 tunneling driver
Jan 27 07:33:02 localhost TCP cubic registered
Jan 27 07:33:02 localhost NET: Registered protocol family 10
Jan 27 07:33:02 localhost IPv6 over IPv4 tunneling driver
Jan 27 07:33:02 localhost NET: Registered protocol family 17
Jan 27 07:33:02 localhost 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Jan 27 07:33:02 localhost All bugs added by David S. Miller <[email protected]>
Jan 27 07:33:02 localhost ACPI: (supports S0 S3 S4 S5)
Jan 27 07:33:02 localhost ReiserFS: sda7: found reiserfs format "3.6" with standard journal
Jan 27 07:33:02 localhost ReiserFS: sda7: using ordered data mode
Jan 27 07:33:02 localhost ReiserFS: sda7: journal params: device sda7, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Jan 27 07:33:02 localhost ReiserFS: sda7: checking transaction log (sda7)
Jan 27 07:33:02 localhost ReiserFS: sda7: journal-1153: found in header: first_unflushed_offset 2041, last_flushed_trans_id 1617016
Jan 27 07:33:02 localhost ReiserFS: sda7: journal-1206: Starting replay from offset 2041, trans_id 1617017
Jan 27 07:33:02 localhost ReiserFS: sda7: journal-1299: Setting newest_mount_id to 225
Jan 27 07:33:02 localhost ReiserFS: sda7: Using r5 hash to sort names
Jan 27 07:33:02 localhost VFS: Mounted root (reiserfs filesystem) readonly.
Jan 27 07:33:02 localhost Freeing unused kernel memory: 324k freed
Jan 27 07:33:02 localhost i2c /dev entries driver
Jan 27 07:33:02 localhost nvidia: module license 'NVIDIA' taints kernel.
Jan 27 07:33:02 localhost ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
Jan 27 07:33:02 localhost PCI: Setting latency timer of device 0000:01:00.0 to 64
Jan 27 07:33:02 localhost NVRM: loading NVIDIA UNIX x86_64 Kernel Module 100.14.19 Wed Sep 12 14:08:38 PDT 2007
Jan 27 07:33:02 localhost kjournald starting. Commit interval 5 seconds
Jan 27 07:33:02 localhost EXT3 FS on sda6, internal journal
Jan 27 07:33:02 localhost EXT3-fs: mounted filesystem with ordered data mode.
Jan 27 07:33:02 localhost EXT3 FS on sda4, internal journal
Jan 27 07:33:02 localhost fuse init (API version 7.8)
Jan 27 07:33:02 localhost fuse distribution version: 2.7.0
Jan 27 07:33:02 localhost Adding 2441840k swap on /dev/sda5. Priority:-1 extents:1 across:2441840k
Jan 27 07:33:02 localhost r8169: eth0: link up
Jan 27 07:33:12 localhost eth0: no IPv6 routers present
Jan 27 07:33:13 localhost device eth0 entered promiscuous mode
Jan 27 07:33:13 localhost br0: port 1(eth0) entering learning state
Jan 27 07:33:13 localhost br0: topology change detected, propagating
Jan 27 07:33:13 localhost br0: port 1(eth0) entering forwarding state
Jan 27 07:33:23 localhost br0: no IPv6 routers present
Jan 27 07:34:03 localhost ata1: D2H reg with I during NCQ, this message won't be printed again
Jan 27 07:35:12 localhost hdf: cdrom_pc_intr: The drive appears confused (ireason = 0x01). Trying to recover by ending request.
