- Jul 31, 2004
- West Virginia
fishy i have been trying to get ahold of you, check your pms
enduro said:All right pardon my stupidity but what is the benefit of using Gentoo over XP? I had never heard of Gentoo until I saw it in Fishy's sig one day.
eNightmare said:would this work in cflags?
-mcpu=athlon-xp -march=i686
i'm not sure if thats the right verbiage but you get the idea.
eNightmare said:everytime I try to compile using the flag -march=athlon-xp, my computer locks up about 5 minutes into it...but it works find with i686
{PMS}fishy said:I never had any luck with AXPs and Gentoo. Could be code related, could be something else. I ended up running a stage 3, it just wasn't worth the fight.
Try upgrading GCC. Also are you OCed at all? It locks as in freezes up, or what actually happens?
eNightmare said:Yes, I am overclocked...but i thought maybe it was a stability issue so I underclocked slightly and tried it again...also tried using the gentoo-nofb kernel...but once I tried -march=i686 it worked beautifully, and i did it a couple of other times to and have worked every time.
EDIT: I should note that this happened while I was compiling the kernel on a stage 3 installation. It just froze up...I couldn't change virtual consoles or anything, and the cursor would freeze as well. Do you know what version of gcc goes on the 2005.0 installation cd?
{PMS}fishy said:Also, any overclock can freak somehting as critical as emerge system out. Run it stock.
eNightmare said:I tried that too...
Is there a huge difference between using athlon-xp and i686?
