Here are my current bios settings. Boot at 585fsb without issues...good stability in windows (passes a few rounds of prime95). Setfsb gets it to 594 before windows freezes.
tia for taking a look and (as always) welcome ideas, guidance, etc
Thanks!
UPDATE: The moocow sticks got here today (thank you again moocow). At the same settings as listed below (except for the ram which I set to it's default of 8-8-8-24 and 1.8v), the new ram let the mobo go to 596fsb. Changing the FSB Strap to 333 and set to DDR3-1872 took the board to 620 (woohoo!! thank moo!!). After getting bsod 50's and adding vDDR, was able to hit 643.5 (
http://http://valid.canardpc.com/show_oc.php?id=2648031 ). Had to take vDDR to 1.988...anything more than that did nothing to increase the top fsb. Guess now the question becomes what setting changes should I try next to see how much further it can go? 650 feels close enough to taste!!! Think 675 might be do-able?
UPDATE2: Won't post at 585x10 anymore
Also...raising setfsb beyond 643.5 doesn't do anything...cpu-z stays at 643.5 (checked the validation file made when setfsb said 648 but still 643.5).
Ai Overclock Tuner Manual
OC From Memory Level Up Auto
FSB Frequency 585
CPU Ratio Setting 6 (at 10x setup's still stable)
> CPU configuration
CPU Ratio Setting 6
C1E Support Disabled
CpU TM Function Disabled
Max CPUID Value Limit Disabled
Vanderpool Technology Disabled
Execute Disable Bit Disabled
Core MultiPprocessing Enabled
* CPU clock skew Auto
* NB clock skew Auto
FSB Strap to North Bridge 266
PCIE Frequency 100
DRAM Frequency DDR3-1476
DRAM Command Rate 2N
DRAM Timing Control Manual
1st information
CAS# Latency 7
RAS# to CAS# Delay 8
RAS# PRE Time 7
RAS# ACT Time 24
RAS# to RAS# Delay [Auto]
REF Cycle Time [Auto]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
2nd information
READ to WRITE Delay(S/D) [Auto]
WRITE to READ Delay(S) [Auto]
WRITE to READ Delay(D) [Auto]
READ to READ Delay(S) [Auto]
READ to READ Delay(D) [Auto]
WRITE to WRITE Delay(S) [Auto]
WRITE to WRITE Delay(D) [Auto]
3rd information
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control Disabled
DRAM Dynamic Write Control Disabled
> DRAM Skew Control :
DRAM CMD Skew on Channel A [Auto]
DRAM CLK Skew on DIMM A1 [Auto]
DRAM CLK Skew on DIMM A2 [Auto]
DRAM CTL Skew on DIMM A1 [Auto]
DRAM CLT Skew on DIMM A2 [Auto]
DRAM CMD Skew on Channel B [Auto]
DRAM CLK Skew on DIMM B1 [Auto]
DRAM CLK Skew on DIMM B2 [Auto]
DRAM CTL Skew on DIMM B1 [Auto]
DRAM CTL Skew on DIMM B2 [Auto]
Ai Clock Twister Auto (Have tried Moderate and Strong Twister and a few Booster settings but system won't boot @ 585 with settings other than auto so far)
Ai Transaction Booster Auto
Common Performance Level []
Pull in of CHA PH1 Disabled
Pull in of CHA PH2 Disabled
Pull in of CHB PH1 Disabled
Pull in of CHB PH2 Disabled
EPU II Phase Control Full Phase (gives about 2MHz higher fsb with setfsb)
CPU Voltage 1.74 (cpu-z shows 1.680 in windows)
Load-Line Calibration Disabled (enabled didn't do anything to improve fsb)
CPU PLL Voltage 1.55
FSB Termination Voltage 1.40
CPU GTLVref(0) +40mv
CPU GTLVref(1) Auto
CPU GTLVref(2) Auto
CPU GTLVref(3) Auto
NB GTLVref Auto
North Bridge Voltage 1.67
DRAM Voltage 1.65
NB DDRVref Auto
DDR3 Channel A Vref Auto
DDR3 Channel B Vref Auto
South Bridge 1.5 Voltage 1.55
South Bridge 1.05 Voltage 1.07
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
