Hi guys, I upgraded my Ryzen 1600 which was working flawless at 4Ghz around 1.39v to a new brand 2700 (was a good deal). My mobo is a gigabyte GA-AX370M-Gaming 3 and well since I installed the Ryzen 7 2700 I'm having problems with the CPU voltage.
By default the auto voltage of the CPU displays values from 1.35-1.4v. However, when I start to overclock the maximum voltage I can reach is about 1.212v, producing low overclock (3.8 Ghz at max). This is due that the voltage is set with an offset in the bios, and setting an offset of +0, produces a voltage of 1.0v, and the range available is [-0.2, +0.2] so I can't go higher. With the Ryzen 5 1600, this did not happen as an offset of +0 produces around 1.3v.
So, I suppose this is a problem of the bios, regarding the "oc mode" of zen+ not working well with this mainboard. I contacted the gigabyte support and their response was that "This is due to the avoid the overheating by the system". I'm still laugthing. However, without solution.
I just want to spread this problem and look for more people having it, so gigabyte has to solve this.
Also if someone has any posible solution in mind, I will be pleased to listen it.
