What power supply do you have?Well I ran memtest86+ for 6 hours. No errors and "Pass" value was 8.
Ought to be solid and enough wattage. What's the particular model? And is your GPU overclocked?Zalman 750W
Thanks. Been out of the loop OC'ing since AMD64, so forgive me if I can't find what CPU Termination is supposed to do?
Bumped up CPU Term two notches (1.22v?) and MCH Core to 1.2v at 453hz FSB and it did not freeze on Test 2 of Prime95 like it did every time before! Thanks cold.nut! Now I can keep moving to find a stable and fast setup. I won't make it to 533hz FSB but it's better than 400hz, and still 1:1.
Another question for you guys: how good is the Gigabyte (JMicron) SATA controller? I'm not using RAID. Are there any benefits to running say the optical drives on the JMicorn SATA and the hard drives on the Intel SATA? Or some other optimal way? Maybe system SSD on standard SATA and storage HDDs on GSATA?
