- May 27, 2001
I have the 8KNXP board, it has everything but SCSI onboard. You should beable to overclock the 2.4C chip a good amount on the 8KNXP Ultra. What type of memory will you be using? You should try to use like 400Mhz or 433Mhz memory with it. The bios that it has from the factory dont support dual channel 400Mhz memory, but it should when they have some new bios out.
Ummmm....
Right now my 8KNXP is running @ a FSB of 1102.70 and a ram speed of 457mhz 2,5,3,3 DDR NO PROBLEMS....This 'the 8KNXP won't support 400 mhz duel channel' is just pure and simple rubbish! 'Of course' it supports 400 mhz DDR ram speeds in duel channel, it's an i875p mobo!!
The 8KNXP has all the overclocking options of the ASUS and ABit boards with a fantastic amount of options like SATA raid and Gigabit CSA lan as well as PATA raid. It also has 6 phase power regulation which means that my Vcore and Vdimm dosen't drop one iota under heavy load using a TopPower 350watt PSU.
The quality and stability of this board is the best bar none....
.....Won't support DDR 400 DUel Channel?! You need better RAM dude - Or up your Vdimm....
