- Oct 24, 2009
- Behind You
Will the GIGABYTE GA-MA790X-UD4P support Quad Cores out of the box? I was reading some reviews on newegg, and people were complaining that only two of the four cores were being read. Is this because of AMD cool n' quiet, or another reason?
I was going to buy one, and thought that it'd be alright since it was probably just the cool n' quiet , that you could disable later on, that was causing the problem with the cores not being read at 3.2 Ghz but 800 Mhz.
Or does the board really not support Quad Cores like the 955 BE for instance? I really want a Quad Core functioning on this board, and will it work out of the box? Or do i have to update bios for the cores to work? Or is it just Cool N' Quiet.
Can someone elaborate for me? Thank you in advanced.
Board=http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
