- Dec 4, 2008
- Thread Starter
- #41
SamSavesMax - thanks for the detailed info. I had a working OC @ 44x, which now refuses to boot. Gets to BIOS splash - but cannot even enter BIOS (reboots).
I either have a bad CPU now or a bad Mobo. But this helps to compare my settings against (we're almost identical - I had lower multiplier & dvid of course).
Lame to lose my system after about 3 weeks operation
Not able to boot into the BIOS sounds really a bad sign.
Your system was set to RAID as I see you have an SSD & HDD...correct...as you're running the OS off SSD?
Was it a successful bios flash? I assumed it's a yes.
Remove rams, remove battery, clear CMOS...and let it seat for 2 hrs.
Check and make sure the rams installed in appropriate slots. (do verify with owner's manual)
If that couldn't do the trick...and still unable to boot into BIOS...then check for your incoming PM as a last resort.
