- Jul 12, 2002
I've decided to buy this board. At $130 it's a no brainer where as the Asus Pro costs $190.
Planning to throw a i5 4670k on it. with a Noctua NH-D14 HS
I took a look at the specs and it says memory voltage at 1.5v.
Does anyone know if bios dram voltage options go higher than 1.5v? I want to buy 1.6v memory modules...
G.SKILL Ripjaws X Series 16GB (2x8GB) DDR3 2133MHz CL9 Dual Channel Kit (F3-2133C9D-16GXH)
What are all the dram bios voltage options?
Thanks in advance.
Thanks in advance.
