- May 6, 2001
- HOT 'n Arizona
Nice set up
Not bad on the BCLK. PCIe on AUTO for that I am assuming?
If that's the same mem you used with the Xeon, it's probably the IMC Did you try single or dual channel or 1 stick at a time to see if a stick went bad? Does it have the same problem at lower BCLK?
Haha, the ole -1 available mem in SPi, haven't seen that in a while
I wish it would crack the 240+ mark, but nice to see it will do 3D06 with that kind of BCLK regardless. I don't think I've done 3Ds over ~225 on the UD4P. 2Ds about 233-235.
I'm still not sure how the hell a SS is running 4/8 @ 4.8GHz+, especially with that much Vc, but that must be the highest capacity single-comp phase unit I've ever seen...and I've seen some strong ones (ie. 1HP rotary).
Keep up the good work, looking forward to more results...
