Yea, Bluray players can have integrated USB ports and can play content from web sites directly.
Standard old DVD players can sometimes only play standard DVD folders, VIDEO_TS folders, you know, the kind that show up when you insert a standard DVD disc in your computer and browse to it.
Editing DVD structure can be complicated business. It's my hobby, by the way, I love to buy complete series on DVDs then make custom DVDs with only the best episodes, combining official menus from multiple DVDs into a single layer DVD, without any compression. It can be quite challenging to combine different DVD structures.
Why don't you guys move away from DVD's and just stream this stuff? Just curious.
Episodes are usually 30-60 minutes. So I edit the menus to include only the episodes which fit as 100% 1:1 data copies on single layer DVDs.
For movies, I have to use dual layer DVDs or one 4TB external hard drive, which is actually enough to fit all Blurays and all stabdard DVDs I own. I buy them and then have to edit them because of the 15 minute needless warnings and previews. Editing Blu-rays is particularly difficult.
If the clip is two hours or less Windows built in media maker thing will do it. Was built into 7 at least, not sure about Vista or 8.
If a two hour movie is bigger than a single layer disk, it is because of bonus features or lower compression encoding designed specifically to make it that little bit harder to copy a movie.
Edit: and if by edit a bluray you mean make it fit on a si gle sided single layer disk, bdrebuilder can do it, but it takes a bit of setting up and support programs , once that's done it's pretty close to a one click compression.
After it is converted to DVD will it be in VIDEO_TS format and play in any DVD player.
I cant remember why is it when you have 2 hour movie on a DVD and you rip it there is more data than 4.7 GB DVD+R,? Is it because movie DVD is MPEG 2.
What extra steps do you have to take to edit a Blu-ray?
