I'm thinking of getting a new GPU and have found a few options. But I'm wondering how well each will play current games. My options so far are as follows. (Prices in $ for comparison)
HD 7850 OC @ 1100/1300MHz 2GB 256bit Cores: 1024 TMU: 64 ROP: 32 ($160)
HD 7870 Tahiti LE @ 925/1200MHz 2GB 256bit Cores: 1536 TMU: 80 ROP: 32 ($240)
GTX 660 TI @ 1000/1500MHz 2GB 192bit Cores: 1344 TMU: 112 ROP: 24 ($250)
The most demanding of the games is Tomb Raider so I'd like to consider that as the basis for comparison. I'd like to be playing at 1080p with all options set to max including TressFX.
The NVIDIA is only 192bit compared to AMDs 256bit, but it has a much higher TMU. Is this better to have than higher streams and ROPs? Also NVIDIA have PhysX and CUDA. Given it has the highest price is this better even though it has a lower bandwidth and ROPs?
If none of these cards will run Tomb Raider at 1080p with TressFX then would 2 HD 7850s in Cross Fire outperform both the HD 7870 Tahiti LE & GTX 660 TI?
Any other choices that may be better at a similar price point?
Thanks in advance.
Thanks in advance.
