Need to unlock bios and OC CPU/GPU Of My Laptop
LSX Monster
Hi guys,
I've bought MSI GT70 0NE-609US laptop with some modifications.
I'm seeking for your experince to help me to overclock cpu-gpu and unlock bios of my laptop
the specification are listed below
Processpr Intel Ivy Bridge i7 Extreem 3940XM 3.0 GHz 8 MBytes Cash
Ram Corsair 32 GBytes (8x4) 1866 MHz
Graphics Nvidia GeForce GTX 680M 4 GBytes
mSATA Mushkin Atlas III SSD 480 GBytes (240GBx2) RAID 0
Specifications with more details after using CPU-Z
Processor: Intel Core i7 Extreem 3940XM @ 3.00GHz Ivy BridgeCore speed 1197.47 MHz
Max TDP 55 W
Core VID .886 V
L1 Data 4x32 KBytes 8-way 64-byte line size
L1 Inst. 4x32 KBytes 8-way 64-byte line size
Level 2 4x256 KBytes 8-way 64-byte line size
Level 3 8 MBytes 16-way 64-byte line size
Cores 4
Threads 8
Mainboard
Motherboard:MSI
Model MS-1762 Rev 1.0
Chipset Intel Ivy Bridge Rev 09
Southbridge Intel HM77 Rev 04
Bios
Brand American Megatrends Inc.
Version E1762IMS.70U
Date 11/32/2012
Graphic Interface
Version PCI Express
Link Width x16
Max Supported x16
Memory
Type DDR3
Channels# Daul
Size 32768 MBytes
DRAM Frequency 931.4 MHz
FSB:DRAN 1:7
CAS# Latency (CL) 10.0 clocks
RAS# to CAS# Delay (tRCD) 11 clocks
Cycle Time (tRAS) 30 clocks
Command Rate (CR) 2T
SPD
Slot#1
Module Size 8192 MBytes
Max Bandwith PC3-14200 (889 MHz)
Manufacture Corsair
Part Number CMSX8GX3M1A1866C10
Serial Number 9276649C
Week/Year 24/12
Timing >>>>>
JEDEC #1
Frequency 558MHz
CAS# 6.0
RAS# to CAS# 7
RAS# Precharge 6
tRAS 18
tRC 27
Voltage 1.5 V
JEDEC #2
Frequency 837MHz
CAS# 9.0
RAS# to CAS# 10
RAS# Precharge 10
tRAS 27
tRC 40
Voltage 1.5 V
JEDEC #3
Frequency 930MHz
CAS# 10.0
RAS# to CAS# 12
RAS# Precharge 10
tRAS 30
tRC 44
Voltage 1.5 V
Graphics
Intel HD Graphics 4000
Memory Size 2047 MBytes
Memory Size 64 MBytes
Graphic specifications with more details after using GPU-Z
Name: Nvidia GeForce GTX 680M
GPU GK104 Revesion A2
Technology 28nm
Die Size 294 mm2
Release Date Jun 4, 2012
Transistor 3540M
Bios Revesion 80.04.33.00.24 (P2051-b002)
Device ID 10DE-11A0
Subvendor MSI(1462)
ROPs 32
Bus Interface PCI-E 3.0x16@ x16 1.1
Shaders 1344 Unified
DirectX Support 11.1 / SM5.0
Pixel Fillrate 24.7 GPixel/s
Texture Fillrate 86.4 GText/s
Memory Type GDDR5
Bus Width 256 Bit
Memory Size 4096 MB
Bandwith 115.2 GB/s
Driver version nvlddmkm 9.18.13.1090 (ForceWare 310.90) / Win8 64
GPU Clock 771 MHz - Memory 900 MHz - Boost 771 MHz
Default Clock 771 MHz - Memory 900 MHz - Boost 771 MHz
Sensors
GPU Core Clock 135.0 MHz
GPU Memory Clock 162.0 MHz
Memory Usage (Dedicated) 0 MB
Memory Usage (Dynamic) 5 MB
VDDC 0.8370 V
If anyone know how to get the maximum power of my CPU GPU RAM and Bios please guide me.
Thanks
be extra careful... usually laptops have just about the smallest possible amount of cooling to work as is. rarely do they have much overclock room as their cooling/heatsink combos rarely are robust enough to deal with it.
I've upgraded cooling/heatsink of my laptop and used extra cooper to make it better. Also I'm using cool master cooling pad (NotePal U3) whic made of an aluminum and has 3 high speed cooling fans. It is pretty good.
Thanks alot for you advice. :bday:
y have a Medion Erazer x6823 whit gtx670mx and y want to change whit the gtx680m.
the problem is de laptop it wont install drivers for the gtx680 and in device manager the laptop se it as a generic graphic card adapter. can someone tell me what to do ?
sory for my English is not god
