GPU Load is low which = Low FPS
jassinlive
So I started to notice I was getting low FPS in games I have been playing for a while now and the only reason I could think for it was because of the recent driver 10.10c hotfix. I downloaded the hotfix because It was supposed to have Fallout NV support.
I noticed in other games my FPS would dip a fair bit in high demand areas where it would usually be a walk in the park so I decided to check my GPU usage with Afterburner OSD and noticed in these high demand areas my load would only be around 25-30% which seemed very odd (In TF2 usually runs flawless never dips 100, but getting around 30 FPS I knew something was not quite right)
I uninstalled the latest ATI driver and re-installed driver 10.8 (only one I had b4 Steam's auto driver update) and still noticed that there wasn't an improvement so my Hotfix theory went out the window. I have just re-installed 10.10.
I also have another theory. I used a .dll fix for the game Fallout NV Click Here which helps the NPC FPS drop in the game. After playing around 18 hours or so I read on the Fallout forum's that someone claimed it wasn't good for your GPU so I deleted the d3d9.dll and haven't used it since. I was wondering if this may have affected my card into less load on games.
Here is a dxdiag:
Code:
System Information
Time of this report: 11/3/2010, 00:12:06
       Machine name: SAM-PC
   Operating System: Windows 7 Professional 64-bit (6.1, Build 7600) (7600.win7_gdr.100618-1621)
           Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
       System Model: System Product Name
               BIOS: BIOS Date: 09/02/09 18:58:13 Ver: 08.00.15
          Processor: Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz (4 CPUs), ~2.7GHz
             Memory: 6144MB RAM
Available OS Memory: 6134MB RAM
          Page File: 2031MB used, 10234MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
        Sound Tab 4: No problems found.
        Sound Tab 5: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: ATI Radeon HD 5800 Series
       Manufacturer: ATI Technologies Inc.
          Chip type: ATI display adapter (0x6899)
           DAC type: Internal DAC(400MHz)
         Device Key: Enum\PCI\VEN_1002&DEV_6899&SUBSYS_0B001002&REV_00
     Display Memory: 3823 MB
   Dedicated Memory: 1012 MB
      Shared Memory: 2811 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: W2261
         Monitor Id: GSM56CF
        Native Mode: 1920 x 1080(p) (59.934Hz)
        Output Type: HDMI
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1047 (English)
     Driver Version: 8.782.0.0
        DDI Version: 10.1
       Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
   Driver Date/Size: 9/29/2010 12:54:02, 628224 bytes
        WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
  Device Identifier: {D7B71EE2-2BD9-11CF-A577-0A2BBEC2C535}
          Vendor ID: 0x1002
          Device ID: 0x6899
          SubSys ID: 0x0B001002
        Revision ID: 0x0000
 Driver Strong Name: oem42.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_Evergreen:8.782.0.0:pci\ven_1002&dev_6899
     Rank Of Driver: 00E62001
        Video Accel: ModeMPEG2_A ModeMPEG2_C
   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Speakers (High Definition Audio Device)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_104383C0&REV_1001
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            Driver Name: HdAudio.sys
         Driver Version: 6.01.7600.16385 (English)
            WHQL Logo'd: n/a
          Date and Size: 7/14/2009 11:07:00, 350208 bytes
            Other Files:
        Driver Provider: Microsoft
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Digital Audio (S/PDIF) (High Definition Audio Device)
 Default Sound Playback: No
 Default Voice Playback: No
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
            Description: Speakers (2- C-Media USB Headphone Set  )
            Hardware ID: USB\VID_0D8C&PID_000C&REV_0100&MI_00
        Manufacturer ID: 65535
             Product ID: 65535
                   Type: WDM
            Driver Name: USBAUDIO.sys
            WHQL Logo'd: n/a
          Date and Size: 7/14/2009 11:06:32, 109568 bytes
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
            Description: ATI HDMI Output (ATI High Definition Audio Device)
            Hardware ID: HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: AtihdW76.sys
         Driver Version: 7.11.0000.7709 (English)
            WHQL Logo'd: n/a
          Date and Size: 8/16/2010 21:42:00, 116240 bytes
            Other Files:
        Driver Provider: ATI Technologies Inc.
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
            Description: Microphone (2- C-Media USB Headphone Set  )
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: C-Media USB Headphone Set
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x0D8C, 0x000C
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3A36
| Matching Device ID: usb\root_hub
| Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Vendor/Product ID: 0x046D, 0xC315
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Logitech HID-compliant G3/MX518 Optical Mouse
| Vendor/Product ID: 0x046D, 0xC051
| Matching Device ID: hid\vid_046d&pid_c051
| Upper Filters: LMouFilt
| Lower Filters: LHidFilt
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 313.3 GB
Total Space: 771.3 GB
File System: NTFS
      Model: WDC WD8088AADS-00M2B0 ATA Device
      Drive: D:
      Model: PIONEER DVD-RW  DVR-218L ATA Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), , 0 bytes
System Devices
     Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_82D41043&REV_00\3&11583659&0&EF
   Driver: n/a
     Name: Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26
Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_836B1043&REV_13\3&11583659&0&18
   Driver: n/a
     Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AA50&SUBSYS_AA501002&REV_00\4&2F1C4782&0&0118
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_82D41043&REV_00\3&11583659&0&D2
   Driver: n/a
     Name: Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20
Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_82D41043&REV_00\3&11583659&0&FA
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_836B1043&REV_13\3&11583659&0&08
   Driver: n/a
     Name: ATI Radeon HD 5800 Series
Device ID: PCI\VEN_1002&DEV_6899&SUBSYS_0B001002&REV_00\4&2F1C4782&0&0018
   Driver: n/a
     Name: Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_83571043&REV_00\3&11583659&0&E4
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_82D41043&REV_00\3&11583659&0&D1
   Driver: n/a
     Name: Intel(R) ICH10R LPC Interface Controller - 3A16
Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_82D41043&REV_00\3&11583659&0&F8
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_836B1043&REV_13\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) ICH10 Family PCI Express Root Port 4 - 3A46
Device ID: PCI\VEN_8086&DEV_3A46&SUBSYS_83571043&REV_00\3&11583659&0&E3
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_82D41043&REV_00\3&11583659&0&D0
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub Throttle Registers - 3438
Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_13\3&11583659&0&A3
   Driver: n/a
     Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_82D41043&REV_90\3&11583659&0&F0
   Driver: n/a
     Name: Intel(R) ICH10 Family PCI Express Root Port 3 - 3A44
Device ID: PCI\VEN_8086&DEV_3A44&SUBSYS_83571043&REV_00\3&11583659&0&E2
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_82D41043&REV_00\3&11583659&0&EA
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_13\3&11583659&0&A0
   Driver: n/a
     Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_824F1043&REV_03\4&37B550F8&0&00E4
   Driver: n/a
     Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_83571043&REV_00\3&11583659&0&E0
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_82D41043&REV_00\3&11583659&0&E9
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_13\3&11583659&0&A2
   Driver: n/a
     Name: D-Link Wireless G DWA-510 Desktop Adapter
Device ID: PCI\VEN_1814&DEV_0302&SUBSYS_3A711186&REV_00\4&1B359D48&0&00F0
   Driver: n/a
Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_83571043&REV_00\3&11583659&0&D8
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_82D41043&REV_00\3&11583659&0&E8
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_13\3&11583659&0&A1
   Driver: n/a
     Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3403&SUBSYS_83841043&REV_00\4&5E2F093&0&00E3
   Driver: n/a
     Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_82D41043&REV_00\3&11583659&0&D7
   Driver: n/a
     Name: Intel(R) ICH10 Family SMBus Controller - 3A30
Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_82D41043&REV_00\3&11583659&0&FB
   Driver: n/a
     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_836B1043&REV_13\3&11583659&0&38
   Driver: n/a
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_82C61043&REV_02\4&9B46FCD&0&00E2
   Driver: n/a
DirectShow Filters
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16597
QuickTime Video Decoder Filter,0x00600800,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0007.3064
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3064
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0007.3064
ATI Ticker,0x00200000,0,1,Ticker.ax,
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16648
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPC - MPEG-2 Video Decoder (Gabest),0x00500001,1,1,Mpeg2DecFilter.ax,1.03.1264.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16648
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
MPC - FLV Splitter (Gabest),0x00600000,1,1,FLVSplitter.ax,1.03.1264.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.09.0042.0001
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.09.0042.0001
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
Haali Video Renderer,0x00200000,1,0,dxr.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.09.0042.0001
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.03.1264.0000
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.03.1264.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.09.0042.0001
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16648
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0007.3064
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
MPC - FLV Source (Gabest),0x00600000,0,0,FLVSplitter.ax,1.03.1264.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0007.3064
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
Haali Video Sink,0x00200000,1,0,splitter.ax,1.09.0042.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0007.3064
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.06.7600.16385
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.06.7600.16385
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.06.7600.16385
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IAC2,0x00200000,1,1,quartz.dll,6.06.7600.16490
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.06.7600.16490
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.06.7600.16490
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.06.7600.16490
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.06.7600.16490
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
Audio Capture Sources:
Microphone (2- C-Media USB Head,0x00200000,0,0,qcap.dll,6.06.7600.16385
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16648
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16648
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16648
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
WDM Streaming Capture Devices:
,0x00000000,0,0,,
C-Media USB Headphone Set  ,0x00200000,2,2,ksproxy.ax,6.01.7600.16385
WDM Streaming Rendering Devices:
ATI HD Audio rear output,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio SPDIF out 5,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16648
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (High Definition Audio,0x00200000,1,0,quartz.dll,6.06.7600.16490
ATI HDMI Output (ATI High Defin,0x00200000,1,0,quartz.dll,6.06.7600.16490
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
Digital Audio (S/PDIF) (High De,0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: ATI HDMI Output (ATI High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (2- C-Media USB Headphone Set  ),0x00200000,1,0,quartz.dll,6.06.7600.16490
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7600.16490
Speakers (2- C-Media USB Headph,0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Any idea of what is going on and what I can do to fix this problem?
Cheers
Intel i7 920 @ 3.4Ghz | Asus P6T | Radeon HD5850 MSI | 3x2GB @ 1600 DDR3 | Western Digital SATA 808GB | Antec EarthWatts 750w | Antec Nine Hundred | Noctua NH-C12P | Logitech MX-518
Have been monitoring the temps with Afterburner OSD and they aren't getting higher then 60, sitting under it actually.
Cheers for the welcome =)
Yeah having been using CPUz for an age now and just downloaded GPUz which was great because I wanted to see if my video card was even attempting to run better. I then realised I also had Afterburner OSD installed so I could actually check in game. In areas where my card would usually dominate it seemed like it wasn't attempting to do anything with loads of 25-30%.
I just cleaned out my entire PC with compressed air and took out my video card for a more in depth clean. It had a bit of dust on the fan and a bit more on the inside. I have noticed the idle temps are cooler by about 1-2 degrees.
I also updated again to the latest video driver (without hotfix c) and gonig to do another test.
Will let you guys know shortly.
Found the Problem. Seems like the clean out did the trick. Tested both the games that it struggled on and the GPU load seems to be normal.
Took a screenshot in game to show it running at 99% where before it wouldn't go over 30.
