boucleinfinie
- Nov 5, 2013
- Alberta, Canada
Hey, chappers. This is my first post, but I've been reading here for years. I'm having this issue with my GPU fans on the ROG Matrix 280x platinum. They are making a droning noise and a noise that sounds like a dying harddrive, what I'd assume would be the fan bearings (or whatever the fan has, I have no idea). Instead of RMAing it I'd rather replace the fans, as I've got a really good overclocking chip. Still testing it out. Maybe I'm just having the AMD overclocking experience for the first time and this is normal. I don't know.
Anyway, I can't seem to find much about GPU fan replacements on the internet.
I've found multiple cheap Evercool fans, but that's not something I want. So it got me thinking: although it'd be expensive, and the fans don't get up to the same RPM, would it be possible to buy something like those 92mm x 92mm x 10mm Noctua fans, pop the hubs off, and stick them on where the GPU fans were? I know I need the thinner fans to do this, and I know I might need to do some wire crimping, but do you guys have any experience with this? Would the more expensive 2200 RPM fans be able to keep up with the heat that some cheaper 3000 RPM fans could keep at 70~80c on a full load?
Thanks for whatever input i get, fellers.
Here's what my computer looks like right now, in case you guys are curious:
ROG Impact
i7-4770k with a noctua nh-d14
8GB 2133mhz ram
ROG 280x platinum, which is a 3 slot card
2x Vertex 3 120gb in raid 0
7200 RPM 1TB HHD
seasonic 750 modular psu
All in my prodigy.
My peripherals worth mentioning:
X-star 27inch 1440p monitor
Roccat kone pure mouse
daskeyboard with mx browns
ROG Impact
8GB 2133mhz ram
7200 RPM 1TB HHD
All in my prodigy.
