- Jun 27, 2003
- Toronto, Canada
Are there any programs to tell you how hot your GPU is getting?
Dave
Dave
Thats not entirely true. Its only the higher range cards that come with a built in temp sensor. Lower range cards like my FX5600 dont have oneVrykyl said:if your gpu is one of the newer nvidia cards (fx era) then they have an onboard temp sensor - look in the video card settings for "temperatures" and itll tell you your lowest idle temp and your current temps. However if you have an ATI card there is no sensor for any program to read - the only way to get gpu temps is with a hardware sensor im afraid
Yeah but thats an Ultra, not a standard FX, probably why. Or it could even be down to the manufacturer.magick_man said:
i had a bfg tech 5200 ultra and it had an onboard temp sensor
~Magick_Man~
