- Sep 13, 2013
I recently RMA'd an Asus P8Z77-V MB because when the system booted up sometimes the CPU base clock would change from 100 mhz to 300-1000. However it was rejected because of a tiny scratch. Since I've got it back I've noticed that when I turn off my PC in the OS, all the fans and lights stay on. I know this board is messed and I'm getting a new one, but is this an issue with the board, or PSU? The PSU has seemed fine, it's a Corsair GS700w, but idk. The other issue since I got back the MB has been my 680 has been locking itself at 535-705 mhz core clock and 415 mhz memory clock. I used driver sweeper to no avail and it only restores 1137 mhz (Gigabyte OC edition) with a reinstall of the driver (Version 320.49). The temperatures under load OC'd to 1188 mhz are 60 degrees max. Will these issues be fixed with a new motherboard, or could it be the PSU starting to fail or even the GPU?
