pavloschristo
- May 22, 2013
Hi there. This is my first post on this forum.
I am looking to buy and build a new gaming system this summer, which will be my second. However I am still learning all about the different components and what to look for. When I bought my first system 3 years ago I didn't really know what I was doing and a friend of mine helped to pick out what I should get. I am wanting to upgrade to a system which will last me a good 5+ years with reliability and most importantly still being able to play and run future games with ease. One thing I haven't managed to get my head around is the CrossFire feature with AMD graphic cards. What are the benefits of having a dual Graphic card system? How do I fully utilize them?
For my new system, I am currently looking at 2 Graphic cards, the 'Gigabyte ATI Radeon HD 7950 Windoforce 3X 3072MB GDDR5 PCI-Express Graphics Card' and the 'Sapphire HD 7870 XT rev2.0 2048MB GDDR5 PCI-Express Graphics Card'. Would having a dual card system massively improve the fps and graphics of my games or would I hardly notice a difference compared to using only one. My main problem at the moment is the budget I'm on, and I'm looking to save money where I can, although I am happy to spend the majority of it on good graphic cards if it is worth it. Should I buy a single Gigabyte card (which is slightly better than the sapphire) and this would be satisfactory, or would I benefit greatly from going with getting 2 Sapphire cards instead. Or would it be worth the extra buck buying 2 Gigabyte cards? Or would having two just be unnecessary?
If this is important the games I mostly play are FarCry 3, Assassin's Creed, Call of Duty, GTA. Mostly those genre of games.
I have 2 monitors, an LG at 1920x1080 and another crappy one at 1280x1024 which I will probably replace in a year or so.
Currently, the system that I am looking to buy (excluding the graphics cards) is:
Another question: is my system good enough and all I should really buy is a new graphics card to last me into the future of new, performance hungry games?
My Current system is:
Thanks in advance for your answers.
- Intel Core i7-3930K 3.20GHz (Sandybridge-E) Socket LGA2011 Processor
- ASRock X79 Fatal1ty Champion Intel X79 (Socket 2011) DDR3 Motherboard
- Seasonic 1000w '80 Plus Platinum' Modular Power Supply
- Thermaltake Armor Revo Gaming Case - Snow Edition
- TeamGroup Xtreem LV 16GB (4x4GB) DDR3 PC3-17000C9 2133MHz Dual/Quad Channel Kit (TXD316G2133HC9NQC-L)3HC9NQC-L)
- Microsoft Windows 7 Professional SP1 64-Bit
- Antec Kúhler H2O 920 Series 4 High Performance Liquid CPU Cooler ( LGA 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM2+ / AM3+)
- LG CH10LS28 BD-ROM 10x BluRay ROM / DVDRW SATA-II Optical Drive - Black (Retail)
- Intel Core i7 930 @ 2.80 GHz
- Asus Rampage II GENE Motherboard
- AMD ATI Radeon HD 5770 XXX (875 MHz, 1028 MB @ 1300 Mhz)
- OCZ 3x2GB DDR3 Triple Channel @ 534 MHz
- OCZ Mod X Stream-Pro 600W PSU
- Coolmaster CPU watercooling block (forgotton the model)
- Intel 330 120 GB SSD
- Windows 7 Home Premium 64-Bit
