- Mar 7, 2008
I ordered this as I wanted a low power GPU for custom build I've been planning since... forever. At 30W TDP this isn't going to stress anything, yet on paper the performance should be roughly in the ball park of the old GTX 750.
The specific card I got is an Asus: https://www.asus.com/us/Graphics-Cards/PH-GT1030-O2G/
This is a full height card. The backplate takes one slot, and only has DVI and DHMI on it. No DP for those that might care. The cooler itself takes two slots and includes a fan. As a low power card it doesn't need any extra power connectors.
In initial testing with Unigine Heaven temps went into the 40's and I can't hear the fan over my other systems. I also used that as reference to overclock, and found I could apply +200 core, and max out the ram slider. That took the ram to 2000, and the core to an indicated boost of 1706. I tried +250 core but that crashed. With OC temps touched 50C and I still can't hear the fan. I would note the power limit seems to be capped at 100%, and I can't relax it. Power is the main throttle for this card. It seems they really want to keep it at nominal power rating, which doesn't seem reported by the card. I wonder if anyone has done bios hacks on it already?
Firestrike came out at 3777 with my 5 GHz coffee lake i3 system. Not doing so well on the hwbot rankings there, wonder if other cards either have capability to relax power limit, or is the CPU contribution swinging it to those with higher thread counts?
