I posted this in the sound forum as well, figured you guys might be able to help me here too.
So, I just installed my new BFG Geforce GTX 260, and in doing so I had to move my SB card down a PCI slot to make room. When I was done I started up my PC again and low and behold, my sound wasn't working. I tried uninstalling and reinstalling my drivers, I tried reseating the sound card, I tried using the old drivers off the sound cards CD, nothing. I can see it in device manager as Creative Sound Blaster X-FI, but when I go to my sound and audio in control panel I get "No Audio Device".
I am pulling my hair out right now at trying to figure out what it is... any ideas?
Here is my DxDiag
System Information
Time of this report: 12/24/2009, 18:49:51
Machine name: PURPLE-D301902A
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.090804-1456)
Language: English (Regional Setting: English)
System Manufacturer: HP Pavilion 061
System Model: EX505AA-ABA m7560n
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, MMX, 3DNow (2 CPUs), ~2.2GHz
Memory: 3070MB RAM
Page File: 382MB used, 4573MB available
Windows Dir: D:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 260
Manufacturer: NVIDIA
Chip type: GeForce GTX 260
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_05E2&SUBSYS_0AC119F1&REV_A1
Display Memory: 896.0 MB
Current Mode: 1680 x 1050 (32 bit) (59Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.8206 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 2/17/2009 17:38:28, 6185088 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 2/17/2009 17:38:29, 6307328 bytes
Device Identifier: {D7B71E3E-46A2-11CF-4F5A-CA2A00C2CB35}
Vendor ID: 0x10DE
Device ID: 0x05E2
SubSys ID: 0x0AC119F1
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: D:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC049
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Saitek Eclipse II Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x06A3, 0x8021
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/23/2001 04:00:00, 59520 bytes
| Driver: usbd.sys, 8/23/2001 04:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/23/2001 04:00:00, 14592 bytes
| Driver: kbdclass.sys, 8/23/2001 04:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 04:43:22, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/23/2001 04:00:00, 23040 bytes
| Driver: mouhid.sys, 8/23/2001 04:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 78.0 GB
Total Space: 78.2 GB
File System: NTFS
Model: Maxtor 6L080L0
Drive: D:
Free Space: 257.0 GB
Total Space: 305.2 GB
File System: NTFS
Model: ST3320833AS
Drive: E:
Model: TSSTcorp CD/DVDW TS-H652L
Driver: d:\windows\system32\drivers\cdrom.sys, 5.01.2600.5593 (English), 8/23/2001 04:00:00, 62976 bytes
Drive: F:
Model: DCDUJKX 5MRWX27 SCSI CdRom Device
System Devices
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_11C1&DEV_5811&SUBSYS_2A34103C&REV_70\4&DC268A3&0&2880
Driver: D:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5624 (English), 8/23/2001 04:00:00, 61696 bytes
Driver: D:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 53376 bytes
Driver: D:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 61824 bytes
Driver: D:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 60800 bytes
Driver: D:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 08:46:40, 6400 bytes
Name: NVIDIA GeForce GTX 260
Device ID: PCI\VEN_10DE&DEV_05E2&SUBSYS_0AC119F1&REV_A1\4&13D46659&0&0020
Driver: D:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8206 (English), 2/17/2009 17:38:29, 6307328 bytes
Driver: D:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:28, 6185088 bytes
Driver: D:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.8206 (English), 2/17/2009 17:38:46, 163908 bytes
Driver: D:\WINDOWS\system32\nvapi.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:29, 667648 bytes
Driver: D:\WINDOWS\system32\nvcuda.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:35, 1560576 bytes
Driver: D:\WINDOWS\system32\nvcuvid.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:35, 401408 bytes
Driver: D:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:44, 9592832 bytes
Driver: D:\WINDOWS\system32\nvcpl.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:31, 13680640 bytes
Driver: D:\WINDOWS\system32\nvmctray.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:40, 86016 bytes
Driver: D:\WINDOWS\system32\nvwddi.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:49, 81920 bytes
Driver: D:\WINDOWS\system32\nvmccs.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:40, 229376 bytes
Driver: D:\WINDOWS\system32\nvmccsrs.dll, 6.14.0011.8206 (Arabic), 2/17/2009 17:38:40, 45056 bytes
Driver: D:\WINDOWS\system32\nvdisps.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:36, 4710400 bytes
Driver: D:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:36, 6586368 bytes
Driver: D:\WINDOWS\system32\nvgames.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:39, 3489792 bytes
Driver: D:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:40, 4280320 bytes
Driver: D:\WINDOWS\system32\nvmccss.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:40, 188416 bytes
Driver: D:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:40, 458752 bytes
Driver: D:\WINDOWS\system32\nvmobls.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:41, 1273856 bytes
Driver: D:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:41, 2854912 bytes
Driver: D:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:46, 3796992 bytes
Driver: D:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:47, 4280320 bytes
Driver: D:\WINDOWS\system32\nvwss.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:51, 2744320 bytes
Driver: D:\WINDOWS\system32\nvwssr.dll, 6.14.0011.8206 (English), 2/17/2009 17:38:51, 3026944 bytes
Driver: D:\WINDOWS\system32\NvPVEnc.ax, 6.14.0011.8206 (English), 2/17/2009 17:38:44, 1253376 bytes
Driver: D:\WINDOWS\help\nvcpl.hlp, 2/17/2009 17:38:31, 177897 bytes
Driver: D:\WINDOWS\help\nvwcplen.hlp, 2/17/2009 17:38:49, 55444 bytes
Driver: D:\WINDOWS\system32\nvcod.dll, 1.04.0000.0033 (English), 2/17/2009 17:38:30, 135168 bytes
Driver: D:\WINDOWS\system32\nvcodins.dll, 1.04.0000.0033 (English), 2/17/2009 17:38:30, 135168 bytes
Name: nForce Memory Controller
Device ID: PCI\VEN_10DE&DEV_02FF&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&05
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02FE&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&02
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_02FC&SUBSYS_00000000&REV_A1\3&2411E6FE&0&10
Driver: D:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 68224 bytes
Device ID: PCI\VEN_10DE&DEV_02FB&SUBSYS_00000000&REV_A1\3&2411E6FE&0&20
Name: nForce HyperTransport Bridge
Device ID: PCI\VEN_10DE&DEV_02FA&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&01
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F9&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&04
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F8&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&03
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_02F0&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&00
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027F&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_027E&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_2A34103C&REV_A3\3&2411E6FE&0&52
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_2A34103C&REV_A2\3&2411E6FE&0&48
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_00000000&REV_A2\3&2411E6FE&0&80
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_2A34103C&REV_A3\3&2411E6FE&0&59
Driver: D:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5587 (English), 8/23/2001 04:00:00, 30336 bytes
Driver: D:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5551 (English), 8/23/2001 04:00:00, 144128 bytes
Driver: D:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 00:42:10, 74240 bytes
Driver: D:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 59520 bytes
Driver: D:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 7168 bytes
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_2A34103C&REV_A3\3&2411E6FE&0&58
Driver: D:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5550 (English), 8/23/2001 04:00:00, 17152 bytes
Name: NVIDIA Network Bus Enumerator
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_2A34103C&REV_A3\3&2411E6FE&0&A0
Driver: D:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0001.6767 (English), 10/12/2007 09:15:00, 22016 bytes
Driver: D:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0002.6767 (English), 10/12/2007 09:15:00, 942080 bytes
Driver: D:\WINDOWS\system32\bdco1.dll, 1.00.0000.6767 (English), 10/12/2007 09:14:00, 9216 bytes
Driver: D:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.6767 (English), 10/12/2007 09:14:00, 9216 bytes
Driver: D:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 9/26/2007 09:07:00, 37376 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0267&SUBSYS_2A34103C&REV_A1\3&2411E6FE&0&78
Driver: D:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 24960 bytes
Driver: D:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 96512 bytes
Driver: D:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 04:00:00, 3328 bytes
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_2A34103C&REV_A1\3&2411E6FE&0&70
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_2A34103C&REV_A1\3&2411E6FE&0&68
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_2A34103C&REV_A3\3&2411E6FE&0&51
Driver: n/a
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0260&SUBSYS_00000000&REV_A3\3&2411E6FE&0&50
Driver: D:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 8/23/2001 04:00:00, 37248 bytes
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
Driver: n/a
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
Driver: n/a
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 8192 bytes
d3d9.dll: 5.03.2600.5601 English Final Retail 8/23/2001 04:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 04:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 04:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 04:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 04:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 82432 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 12/24/2009 12:20:45 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 12/24/2009 12:20:40 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 12/24/2009 12:20:41 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 12/24/2009 12:20:41 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 12/24/2009 12:20:42 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 12/24/2009 12:20:42 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 12/24/2009 12:20:42 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 12/24/2009 12:20:43 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 12/24/2009 12:20:43 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 12/24/2009 12:20:43 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 12/24/2009 12:20:45 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:45 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:46 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:46 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:46 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:44 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:45 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 12/24/2009 12:20:44 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 04:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/23/2001 04:00:00 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 8/23/2001 04:00:00 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/23/2001 04:00:00 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 20480 bytes
qasf.dll: 11.00.5721.5233 English Final Retail 8/23/2001 04:00:00 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 733696 bytes
quartz.dll: 6.05.2600.5822 English Final Retail 6/3/2009 14:12:21 1291264 bytes
strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 03:00:21 247326 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/23/2001 04:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/23/2001 04:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/23/2001 04:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/23/2001 04:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/23/2001 04:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/23/2001 04:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/23/2001 04:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/23/2001 04:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 04:01:48 204800 bytes
ks.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 English Final Retail 4/14/2008 05:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 English Final Retail 4/14/2008 05:41:58 4096 bytes
stream.sys: 5.03.2600.5512 English Final Retail 4/14/2008 00:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 19:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 19:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 4352 bytes
mstee.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:09:52 5504 bytes
ipsink.ax: 5.03.2600.5512 English Final Retail 4/14/2008 04:42:44 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 118272 bytes
ndisip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:16:24 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:16:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 8/23/2001 04:00:00 1428992 bytes
slip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:16:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:16:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:16:24 17024 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 16896 bytes
kstvtune.ax: 5.03.2600.5512 English Final Retail 4/14/2008 04:42:44 61952 bytes
ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 04:42:44 43008 bytes
kswdmcap.ax: 5.03.2600.5512 English Final Retail 4/14/2008 04:42:44 91136 bytes
vfwwdm32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 04:42:10 53760 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 23:16:26 19200 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 8/23/2001 04:00:00 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
CC Decoder,0x00200000,2,1,,5.03.2600.5512
WST Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
QuickTime Audio Decoder Filter,0x00600800,1,1,,
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo 8 Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
QuickTime Video Decoder Filter,0x00600800,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.01.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5822
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8081.0709
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0005.0000
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.00.0012.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,3.00.0000.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5822
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5233
DivX AAC Decoder,0x00800000,1,1,daac.ax,7.01.0000.0010
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,3.00.0000.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5822
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0004.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5822
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.03.0001.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5822
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5822
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5822
Essien R&D MPEG Writer Filter,0x00200000,2,0,mpgfiltr.ax,2.05.0001.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
WAV Dest,0x00200000,0,0,viscomwave.dll,9.00.0000.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5822
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5822
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5822
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,6.00.0002.0000
Stream Control Filter,0x001fffff,1,1,StreamCon.ax,1.00.0000.0001
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0003.0000
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,3.01.0003.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
Xvid MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0008.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5822
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5822
Peak Follower Filter,0x001fffff,1,1,PassPeak.ax,1.00.0000.0003
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5822
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,8.02.0000.0026
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5822
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,7.00.0000.0031
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,3.00.0002.0000
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0002.0000
Creative Audio Gain Filter,0x00200000,1,1,AudGain.ax,1.00.0000.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5233
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,3.00.0002.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
AudSkip Filter,0x001fffff,1,1,AudSkip.ax,1.00.0000.0004
CT HPVirtualizer filter,0x00100000,1,1,Virtual.ax,1.00.0000.0000
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
DivX MKV Demux,0x00200000,0,1,DMFSource.ax,1.00.0001.0004
CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0013.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5822
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Creative PCM Raw Writer,0x00200000,1,0,RawWrit.ax,1.00.0000.0000
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0002.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,3.00.0010.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
IVF source filter,0x00600000,0,1,Ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.01.0000.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5822
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5822
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5822
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5822
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5822
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5822
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5822
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5822
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5822
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5822
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0002.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5822
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5822
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,Ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,Ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5822
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX 6.8.5 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
DivX 6.8.5 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5822
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5822
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5822
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5822
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.5822
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5822
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5822
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5822
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5822
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5822
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5822
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5822
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5822
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5822
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5822
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5822
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5822
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5822
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5822
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5822
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
Here is my DxDiag
System Information
Memory: 3070MB RAM
DxDiag Notes
Direct3D: 0/4 (n/a)
Display Devices
WHQL Logo'd: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x05E2
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description:
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
HW Memory: 0
Registry: OK
DirectMusic
Acceleration: n/a
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: n/a
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Registry: OK
USB Devices
+ USB Root Hub
| Service: usbhub
Gameport Devices
PS/2 Devices
| Service: kbdhid
| Service: TermDD
| Service: mouhid
| Service: TermDD
Registry: OK
DirectPlay Adapters
MS-PCM 64 kbit/s
Drive: C:
Free Space: 78.0 GB
File System: NTFS
Drive: D:
File System: NTFS
Model: ST3320833AS
Drive: E:
Drive: F:
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
DirectX Components
DirectShow Filters
DirectShow Filters:
Video Compressors:
Audio Compressors:
Midi Renderers:
BDA CP/CA Filters:
Audio Renderers:
