- Feb 28, 2004
- Claymont Delaware 19703
Ok i have two GTX 260's both are part number 896-P3-1260-AR but the one i got from newegg has superclock speeds but its not a superclock card.The bios versions are the same.Oh and i have not flashed the bios.Anyone ever have this happen
I got this same card from both step up and the second one from newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130370
Field Value
Graphics Processor Properties
Video Adapter nVIDIA GeForce GTX 260
BIOS Version 62.00.0E.00.62
GPU Code Name GT200
PCI Device 10DE-05E2 / 3842-1260 (Rev A1)
Transistors 1400 million
Process Technology 65 nm
Die Size 576 mm2
Bus Type PCI Express 2.0 x16 @ x16
Memory Size 896 MB
GPU Clock (Geometric Domain) 576 MHz (original: 576 MHz)
GPU Clock (Shader Domain) 1242 MHz (original: 1242 MHz)
RAMDAC Clock 400 MHz
Pixel Pipelines 28
TMU Per Pipeline 1
Unified Shaders 192 (v4.0)
DirectX Hardware Support DirectX v10
Pixel Fillrate 16128 MPixel/s
Texel Fillrate 55296 MTexel/s
Memory Bus Properties
Bus Type GDDR3
Bus Width 448-bit
Real Clock 999 MHz (DDR) (original: 999 MHz)
Effective Clock 1998 MHz
Bandwidth 109.3 GB/s
Miscellaneous
Fan Speed 0%
nVIDIA ForceWare Clocks
Standard 2D GPU: 300 MHz, Shader: 600 MHz, Memory: 100 MHz
Low-Power 3D GPU: 400 MHz, Shader: 800 MHz, Memory: 300 MHz
Performance 3D GPU: 576 MHz, Shader: 1242 MHz, Memory: 999 MHz
Graphics Processor Manufacturer
Company Name NVIDIA Corporation
Product Information http://www.nvidia.com/page/products.html
Driver Download http://www.nvidia.com/content/drivers/drivers.asp
Driver Update http://driveragent.com?ref=59
Field Value
GPU Code Name GT200
Die Size 576 mm2
Memory Size 896 MB
Pixel Pipelines 28
TMU Per Pipeline 1
Bus Type GDDR3
Bus Width 448-bit
Miscellaneous
Fan Speed 0%
