Having tried to get help at national boards, I now turn to Overclockers for guidance, really hope I can get some help here.
I want to install water cooling in my system, but I am having some issues deciding which setup to buy.
Here are my computer specifications:
Here is the setup:
What do you think about this setup? My number one priority is silence, I also want a quality build.
Should I go for another brand? Perhaps EKWB?
What connections should I use? I have not choosen any, as I have no clue what will fit.
I already have Noctua 140 mm PWM fans.
Really appreciate some help, I have no experience in water cooling what so ever..
Case: FD Define S
MB: P67A-GD65
CPU: i5 2500k @stock
RAM: Kingston HyperX 2x4GB 1600MHz
SSD: Crucial BX100 250GB
GPU: Sapphire 7950 Dual-X Flex Edition 3GB @stock
PSU: XFX 750w modular
MB: P67A-GD65
Here is the setup:
Radiator: Alphacool NexXxoS ST30 Full Copper 420mm
Pump: Phobya DC12-400 PWM 12Volt
Reservoir: Phobya Balancer 250 black nickel
CPU-block: Phobya CPU-Cooler UC-1 Extreme Intel 775,1150,1151,1155,1556,1366,2011 - Brass Edition
CPU-backplate: Phobya CPU Mainboard backplate 775/1366/1155/1156/2011
Thermal-paste: GELID Solutions GC Extreme Thermal Compound
Tubing 4x: Tubing PVC 13/10mm (3/8"ID) high flexible clear
Coolant: Innovatek Protect concentrate by Aquatuning 500ml
Whole setup: http://www.aquatuning.se/AtsdCartSave/load/AtsdCartSaveKey/dff6533e4c3bd8792d281ba8727cfbf8
