Hi,
What type of noise are you experiencing? Is it a grinding noise? or just fan noise?
If you plugged the fans into a motherboard header that could be your problem.
Yea pressing the button isnt gonna do anything to the fan speed unless the fans are plugged into the pump...
well im on my 3rd h80 in 2weeks . 1st was rma`ed due to loud pump (like a old seeking hdd) 2nd due to faulty pump (bad temps) . 3rd works grate so far lol i think corsair are haveing big problems with their h80 and h100 . when they work right they do work well .
