Ended up replacing all the fans in my case with Noctua A series (Chromax). Why - just felt like it.
Temps are pretty good, vertical GPU and top CPU radiator yields the best overall thermal results. Changing the Arctic P14 fans to Noctua NF-A14 did not make a significant difference, but changing the 2x 200mm CM fans to 2x Noctua fans did drop GPU temps by 3c and reduced all humming/vibrational noise. On the other hand, the Noctua fans are not RGB, but this is not an issue, the emphasis of my build is stealthy black/white/silver with no aRGB madness
