Divinenite
- Jul 14, 2013
Hello all,
This is my first post here . I recently built a mid grade gaming comp 1 month ago and finally got around to stress testing my rig.
I used Prime95 (blend test) and ran it for 6 hours (at night, temp in room was roughly 60 degrees F). I also moved the Case to an open area. The results concern me though.
After 6 hours, my max temp recorded (though HWmonitor) was 98 C and averaged 80 C. For the first hour, max temp was 78 and idled around 68 C.
My Rig is as follows:
Asus Z87-Plus mobo
I5-4670K intell cpu
16 GB Corsair Vengeance (1600 MHZ)
Asus Geforce GTX 660 TI
HAF X 942 (case)
Fans for case currently (currently all stock for now):
1x200 mm side fan (~650rpm) intake
1x200 mm top fan (~650 rpm) exhaust
1x230 mm front intake fan (~640 rpm)
2 x 120 mm exhaust (radiator fans)(~2300 rpm)
H80I Corsair hydro series (radiator+ fans are mounted in the back)
Now i do have another 200 mm after market CM fan and 2x corsair 120 mm after market fans (to replace stock radiator fans)
I do plan to eventually replace all stock fans with after market.
Is there anything i could/should change here? I do want to overclock in the future, but if a stress test is pushing 100 C, then i feel i need to lower that temp first.
Any help is very appreciated!
Asus Z87-Plus mobo
I5-4670K intell cpu
HAF X 942 (case)
