- Sep 5, 2002
- Boise, ID
Hello everyone,
I too got on the bandwagon like you to try the Radeon 9500 hack. I like tinkering with things and therefore couldn't resist ordering a Radeon 9500 Sapphire 128MB OEM card from Newegg last week. The card arrived on Friday.
First thing I did when I got the card was to run a couple games to see if the card was running OK. It seemed to function fine. I then ran 3dmark 2001 SE and got a 3D Mark score of about 11780. This didn't impress me at all honestly because my Radeon 8500 running at 310Mhz core / 300Mhz memory was giving me almost the same exact score. Granted, the 9500 can take over the 8500 when overclocked but believe me, the fps difference in games is not significantly different even with an overclocked 9500 than a 8500.
OK, it was then time to perform the conversion hack. Just like you guys, I also had to spend some hours to get the thing to work but it worked fine in the end. For those of you still having problems. I found out that the guaranteed way to get the hack to work is to follow these steps:
1-Uninstall ATI control panel from Windows Add/Remove programs. Do NOT reboot.
2-Uninstall ATI Display driver from Windows Add/Remove programs. Do NOT reboot.
3-Put the setup files for the driver of your choice to install into a temporary directory on your hard disk. To do this, run the executable file to install the driver, when the installer asks you where you want to put the setup files on your hard disk, point to a temporary folder like I mentioned above and when the ACTUAL installation screen pops up after this, just cancel. DO NOT install the drivers yet. All we did so far is to extract the setup files from the single installation file you download from ATI's website or whereever to a temporary folder on your hard disk.
4-Make a search for the ati2mtag.sys file on your entire hard disk (all partitions) . A copy should be found under Windows\System32\Drivers. Right click on this file from the search window and choose copy. Now make a search for the ati2mtag,sy_ file. This file should be located in a subfolder under the temporary folder where you copied the setup files earlier. Go to this folder. Right click any empty area in this folder and choose paste. We have now copied the ati2mtag.sys file from Windows\System32 folder to the folder where you have the ati2mtag.sy_ file so they are both in the same place. Now make another search for the ati2mtag.sys file on your har disk. DELETE ALL copies of this file except the one you just copied to your temporary folder. So now the ati2mtag.sys file is ONLY located in your temporary folder and nowhere else.
5-Run the RivaTuner script to do the conversion hack. When the script asks you for the ati2mtag.sys file, point to the subfolder under your temporary folder where your setup files are. Patch the file that is in this folder. We have now patched the file we had copied from the Windows\System32 folder. Run the Riva Tuner script again. This time, for the file type, choose the ati2mtag.sy_ file and again point to the same folder that you just did. Now, patch the ati2mtag.sy_ file.
6-OK, now reboot.
7-When you reboot, Windows will ask you for the installation files for your graphics card. DON'T let windows install drivers automatically for you. Choose the "Install from a list of specific location" option and then point to the temporary folder where you put your installation files. Here, you might need to point to a subfolder in your temporary folder for Windows to find the .inf files which identifies your adapter. When this is done, windows will start installing the drivers and tell you that the driver you are installing is not certified. This is GOOD! Choose "continue anyway". When the drivers completes installing, you should be prompted to to do the same thing again, this time for the "secondary display". This is fine too, just do the exact same thing you did a moment ago and point to your temporary folder where the installation setup files are. When the "secondary display" is also installed you should be good to go. If you are prompted to restart, do so but in my case I don't believe I had to.
To find out if this worked, go to your display properties, go to the settings tab and the click the advanced button here. From there, click on the adapter tab and you should see Radeon 9700 for the cchip type and NOT Radeon 9500.
If this didn't work for you, I don't know what to say! I don't think the instructions I wrote could be more detailed. If you follow them to the letter, the conversion hack should work.
So, this was the good news. The hack by all means works. NOW THE BAD NEWS:
After I converted my Radeon 9500 non pro to Radeon 9700, first thing I did was to run 3dmark 2001 SE. I watched all screens carefully looking for artifacts and saw none. No checkerboards, no white dots, everything looked great. My 3D mark score went up al the way close to 14xxx from the 11780 I was getting earlier. This with the default core clock speed of 277Mhz and memory speed of 270Mhz. I decided to overclock the card some and was able to take the core up to 380Mhz and memory up to 300Mhz. Pretty sweet eh? Funny thing is Powerstip wouldn't let me go above 380Mhz for the core so this card might reach a higher core speed. (This is after I edited the pstrip.ini to alter the defaults so that I can move the slider bar higher). I ran 3DMark 2001 SE again. This time almost 16000 3Dmarks and still no artifacts whatsoever.
So if you read this far, you must now be wondering what the bad news is. After all everyhing sounds great so far right?
That's what I thought but it turned out that not everything is great. I fired up Soldier of furtune 2 and guess what? I started seeing a whole lot of shiny strange lines on some parts of the map. I then ran Urban terror which is a Quake 3 mod and guess what? I saw some flashing lines on some trees this time. I then ran some other games, this time directx ones. All in all. here is a list of the things I ran and my results:
1- ALL ATI DEMOS (Radeon 9700 and Radeon 8500 demos) NO artifacts whatsoever anywhere.
2-Unreal Tournament 2003 (DirectX) No artifacts anywhere.
3-Warcraft III (DirectX) No artifacts anywhere.
4-Medal of Honor (OpenGL) Didn't see any artifacts but didn't play too much.
5-Soldier of furtune 2 (OpenGL). Lots of artifacts.
4-Urban terror (OpenGL) Lots of artifacts.
SO THE SUMMARY OF THIS LONG POST IS THIS: IF YOU DID THE HACK AND DIDN'T GET ANY CHECKERBOARD ARTIFACTS LIKE OTHER PEOPLE AND EVEN IF ALL YOUR DIRECTX STUFF LOOKED GREAT, YOUR CARD MIGHT STILL BE DEFECTIVE IN ANOTHER WAY. In my case the defects ONLY showed up in OpenGL games but not even all OpenGL games (Medal of Honor didn't show any artifacts).
The moral of the story here is don't get too excited if your mod works and you don't see any artifacts in 3DMark 2001. It would seem that pipeline defects can present themselves in different ways. I would really like to hear from the people who say that their mod went totally successful if all of their OpenGL games look OK. Some people who are saying that everything is looking great might end up finding out that there are some artifacts in certain games like I did.
I bought this card from Newegg for $160 and now it is going back. I have to pay the shipping for RMA and a %15 restocking fee. Worth the price of an adventure I guess... Just don't have your hopes up for this mod. It seems that 7 out of every 10 card is defective in some way. This makes sense actually because I had read an article some time ago that the high end video cards had extremely low yields which contributed into their sky-high prices. This was certainly true for the Radeon 9700 Pros when ATI started producing them so there were a whole lot of junk for ATI initially which are now being sold to us as Radeon 9500's unfortunately.
6-OK, now reboot.
