its not nessasery to get a better iron - i only suggested wellars or ersa's if people didnt already gave an iron. Wellar's can be picked up pretty cheap, ersa's? i dunno. my ersa iron at work was purchased for £85, and that was half price lolCreig said:James.Miller, you seem like somebody in-the-know on this subject. I'm a fair hand at soldering but given the size (or lack of) this resistor shift and the fact that I would need to spend $ on a higher quality iron I'm thinking that it would be best to just pop the heatsink off this thing and take it to a professional.
Would most any decent electronics repair shop be able to do this properly? And I'm guessing that a pro could probably do this in 5 minutes or under. What would you say would be a fair price for a shop to charge? $10 or under?
Creig said:
I can't see how that would be possible. ATI would have to identify WHICH pipes work, which didn't and modify the PCB to use only those specific four good ones. It makes much more sense that ATI would simply chuck the ones without all eight pipelines working properly and simply disable the same four pipes on all the 9500 boards.
Now as to the artifacts, what happens when you overclock a GPU? You get artifacts. How do AMD and Intel determine WHICH processors are sold as higher clocked than others? By testing them first and sorting which ones perform within spec at default voltage with stock cooling. Those that don't make the cut are tested lower and lower until they either find a speed that the chip will handle at default voltage and heat levels or they toss it in the circular file (ie - garbage).
That is not the one I am talking about. The one I am talking about is here. It is the one at the top of the list. Near the end of the description right before the see it link it says "powered by ATI Manufactured by Sapphire Technologies". By the way it is now 3 dollars cheaper than what I paid for it yesterday!HeXenViRii said:the only sapphires that newegg sells are the 64mb ones ; isnt it ???
http://www.newegg.com/app/viewproduct.asp?DEPA=&submit=Go&description=sapphire+9500
the oem 9500 128mb's dont say wether or not they are sapphire cards only the 64mb version does ....
Smultron said:DONT GO MODDING YOUR CARDS IT SEEMS THAT THIS MOD CAN BE DONE BY SOFTWARE!
Latest news: http://www.digit-life.com/news.html?1093#1093
Thanks a bunch Smultron for finding this That is truly good news. I wonder when this next version will be out? I don't doubt the legitimacy but I wonder how you can get around a resistor disabling 4 pipelines with software? I can't wait to see benchmarks. I will just use that 9500 128mb stock until I see this done!Smultron said:DONT GO MODDING YOUR CARDS IT SEEMS THAT THIS MOD CAN BE DONE BY SOFTWARE!
brint said:But like she also said
