- Jul 8, 2012
I have Windows 10 Pro on a ssd. Then I have two mechanical drives as storage, 2nd redundancy.
I have power option to turn off drives after 30 minutes. Most of the time that seems to be the case. The problem is that they often come back on in few minutes or hour later, while nothing is running. System is on 24/7(more of a home server), I don't need drives running over night...
Steps I have performed
Fully excluded mechanical drives from Windows Security.
Indexing is disabled on those drive plus Window Search service is turned off.
I turned off a bunch of other windows services/apps too, like windows store
I don't want windows turning on and off my hard drives repeatedly, I know its bad if often enough. but at the same time, they have have to be running overnight not in use, plus if I'm in my office, I can hear them spinning.
