Joeteck
Retired
- Oct 5, 2001
- Long Island
There's not much of a downside, and you can always revert back to stock, sans root.
Rooting lets you do a lot of nice things, though- side-loading (in case your carrier prohibits that); Metamorph; WiFi Tether..
I'm not sure what you can screw up on these things. To root the Droid (pretty sure this doesn't work on 2.2), you simply drop a specially crafted "update.zip" file on the phone's SD card, restart it to the recovery console and tell it to use that file. Less than two minutes later, it is working. The Droid is the absolute easiest to root. From there, install "ROM Manager" from the market and put whatever operating system you want on it. I'm running CyanogenMod-6.0.0-Droid-RC1 (2.2 Froyo). Combine that with [paid] program, "SetCPU", you can run the Droid at 800mhz. It made a huge difference.
Is rooting same as jailbreaking?
Sent from apple iphone 4
You guys are so lucky, I want an Android phone... but I'm stuck with Rogers here in Canada and they don't have any decent Android phones...
