- Apr 26, 2009
- Athens, Georgia
I have a wierd problem. For some reason MY Gigabyte GA-MA790X-UD4P motherboard with a OCZ Low Voltage 1066 4GB kit installed will give 2.05v to ram when "normal" is selected for ddr2 1.8 voltage (as listed in bios) If I increase the voltage by +.1 volts, the motherboard instead of giving true voltage of 2.15, applies less voltage of 1.95. From there the scaling is correct, as each +.1 increment is applied, voltage increases appropriately. However this motherboard should allow 1.8 volts (or 1.85 if slightly overvolted), but the least applied to ram is 1.95. I ended up Returning this ram after trying various bios without successfully being able to apply 1.8volts or close.
Has anyone experienced this with their motherboard and Is it a software (bios) issue or some type of regulator that is bad???????? Should I be trying to RMA my board??????
