Just put a new system together & I having a couple of problems with it. short specs are as follows
a7n8x-e mboard
2500+ mobile
PQI DDR 400(PC3200)512mb
Cas Latency: 2.5-3-3-7
Support Voltage: 2.6V
radeon 9600 pro 256mb
volcano 12 HS + Fan
Artic silver 5 thermal paste
400w psu
The problem I am having is I cannot get the memory to boot at 200mhz and it is driving me crazy. The processor is running at 2.4ghz(219x11/1.6v) but I have to set the memory at 83% which puts its speed at 181mhz. I know I can get it to go higher by raising the cpu bus speed. but is that safe? If I try to run it at 200mhz, it just won't boot up & I have to clear the cmos to get it to boot. If I run it at 200 & up the voltage on the mem to 2.7 or 2.8 it will pass the POST, but hangs before loading windows & I have to reset. I do have the pci/AGP bus locked at 66mhz. Does anybody have any suggestions on what to do? I know I can just leave it as is, but how much will that effect the perfomance of having the mem bus speed lower that specified, or just not running in sync with processor?
a7n8x-e mboard
2500+ mobile
volcano 12 HS + Fan
400w psu
