- Aug 19, 2005
- Los Angeles, California
So I found where the metalized holes matches the motherboard holes, and I screw on the golden hand screws into the case (no removable tray).
The problem is that the IO Shield (that thing, thats not mine though) has these spokes that point towards the inside of the case and the motherboard doesn't really match up to the holes, it almost does.
My question is do I remove these spokes or just push the motherboard against them? What are they for?
Ugh everything is so delicate I'm afraid Im going to break it.
