- Nov 7, 2004
I am experiencing a weird crashing issue when playing Fallout 3 I can only narrow it down to it being a ATi problem because when I had my 9600GT 512Mb card it never once crashed at all.
I upgraded to a HD5770 1GB thinking it would up the anti on the game it managed to play it on 1300x768 on high be it will struggle should there be a fight with a few people involved. I updated to the 10.10 driver as I was previously using the 10.5 due to the scaling issue not being fixed in 10.9 for my HDTV.
I can play the game a while then it will suddenly just stop all by it's self and go back to the desktop, I have done the following to see if it will help with my problem.
1) Re-installed DX 9.0c June 10 in case it was a DX error.
2) Removed the 10.10 driver using it's own set-up remove program, rebooted deleted the folder for the display driver and used driver sweeper to remove any other files. It even found some nVidia ones and removed those as well as my SMBUS ones so had to re-install them.
3) Re-installed the 10.10 driver and still testing to see if it crashes again.
I am at a pickle its the Game of The Year edition patched to the 1.07 Uk patch and seems to crash since upgrading, the card is now OCed nor is my CPU and temps sit around 48 after a 4hr play on the GPU the CPU sits around 44.
