- Dec 3, 2011
Hello fellow overclocks,
I just recently acquired a new Insignia NS - LCD19 Tv that i have hooked up to my ATI 4870 card. I hooked up HDMI from the tv input to DVI on the card. This is working fine, but i can't seem to find a good resolution to fit the LCD TV monitor, so it doesn't have any interference with Digial signal going over HDMI - DVI. I also have a Dell LCD 19 monitor connected DVI - DVI on my ATi 4870 card, so this is dual monitor setup. The Dell LCD Monitor looks more crisp then the Wide screen Insignia Tv monitor.
What i have tried: When into Control pannel --> Screen resolution -->
Tried changing the resolution to 1920 X 1028 .. This resolution works fine, but when i drag a window it seems to be larger than the Dell monitors resolution.
Also went into the AMD catalyst control center and messed around with the monitor resolution in "My digital Flat panel settings" Changing resolution to 720p 60hz . work with no interference to the digital signal. Tried 1080i 25hz or 30z. works, but it has a little fuzzy display. Like the window is constantly trying to refresh. 720 60hz .. the windows are bit to large for my preference.
My question is: how can I setup up the Insignia LCD 19 widescreen and the Dell 19 LCD monitor correctly to output a nice native resolution matching both monitors.
Here is my secondary monitor i am using:
http://www.insigniaproducts.com/products/televisions/NS-LCD19.html
Main monitor is just a Dell LCD 19 monitor.
Let me know thanks!
-Darkclock
Let me know thanks!
-Darkclock
