I would imagine that depends on the bios setting. If its on auto, it should hit them both. If it you force the PEG, it wouldn't. That said, I dont know how smart mobos are in that it would recognize a card, its bad, and failover to the iGPU. If it senses something in the slot, it probably just uses it.Im wondering if the memory on the card is failing, forcing the IGP to take over. AM3 has no igpu, so it would still force the card to operate. If the discrete card faults, wont the igpu take over?
When you go into windows, can you open your driver panel (hardware monitor) and look at your display adapters? I think that would answer a few questions as to if the card is even being read.
He cant boot with it in, how can get to device manager (what I think you intended to say)?
