- Jan 13, 2013
- Orange County, CA
I'm just waiting for an ISO to download so I can reinstall my Windows 7 OS on one of my systems. Could have been saved, but I don't keep data on the OS drive, so this is just easier. Main warning sign: idle GPU temps in the 50-60c range! No other indicators in terms of CPU or easily suspect memory consumption! Keep HW monitor open if you're using Java on your system!
This was a pretty well designed and stealth bug. It was masked well from showing CPU activity or anything obvious in task manager or resource monitor. Once I figured out the windows services it was masking itself as, I couldn't use any of the normal tactics to shut down the process regardless of what I tried. Security Essentials missed it twice, so did Avast. Some research online pointed to a program that exploits Java for some sort of bitcoin scheme, and sure enough I had just installed java for the first time on this specific PC on Monday. Services and tasks it was running as or using were a match for what I had read about as well, and so apparently that's what it was.
I generally had gotten apathetic about using any sort of security software at all, since I have used luck and common sense to successfully avoid a single virus/malware issue for what must be five or more years. Not certain where this came from, but it got in quietly. Just watch out!
