- Apr 25, 2006
Well this is my first post... hooray.
Anyway, last year i had the distinct displeasure of installing a couple of commercial refers in my wife's store. So I learned a lot about refrigeration, bought some interesting tools, and hooked it all up. Fast forward to yesterday...im sitting here at my computer thinking damn this thing is loud and putting out some heat. So I start looking around at water coolers etc. So I started thinking about refrigeration and how the heat is transferred by the action of the refrigerant changing state from gas to liquid etc.
So i thought...hmmm, why cant you just charge some vacuumed / sealed tubing with some r134a or something similar and let gravity/heat/capilary action do the rest? I thought naahh, im dreaming. After all, im not that smart on refrigeration.
Low and behold, i was not far off base.
http://www.cheresources.com/htpipes.shtml
Seems possible after all.
Benefits: No moving parts. No compressors. High heat capacity/transfer rate.
Now, the only question left is, is it plausible for PC cooling?
I was thinking about this project I saw where a guy sealed a case and poured veggie oil in it. Then i thought, hmmm i could build a plexi case with room for a condensing coil under the mother board [on the other side of the plexiglass bottom]. So I started sketching and decided to pop in here and tell ya'll about the heat pipes. Maybe stir up some like minded interests...
edit:
seems there is a write up on this:
http://www.benchtest.com/heat_pipe1.html
Regards,
Mark
edit:
Regards,
Mark
