Blimey, what a palaver Windows is. I'm probably making all sorts of basic mistakes. It seemed to take about 5 reboots to install the system, and within an hour of getting up and running, a bit of noodling around looking online for game demos etc, something had changed my Chrome default search from Google to Ask Jeeves. How does stuff like that happen? Does that suggest I've already got malware? I certainly didn't agree to any 'Do you want to change your default serach engine?' dialogue.
So just a quick ask if there's anyone who can point me at a savvy noob's guide to windows. It would be good if I could set it up so that it asks for a password if anything wants to change settings. I don't think I could ever see it being my main OS, but a bit of web access on the gaming machine seems necessary and I want to stop it pissing about changing my settings. The update thing in windows appears a bit basic, as it seems to require a lengthy reboot (or two) rather than just running in the background, so a way of streamlining that would be good too.
Also, the last time I used Windows was 98 and XP and they seemed to have a habit of sort of silting up and becoming slower. I could never work out why. Has this been fixed in the newer versions? I'm still on 7, if it makes a difference.
Mind you, I quite like the file structure. I'm sort of used to drives having moint points within a file system that starts at /root rather than having them all at the top, so that's quite transparent.
Thanks in advance
Fid
Thanks in advance
Fid
