- Jun 27, 2012
Hello everyone. Been a while since I've posted anything. My liquid loop has come very far since I started watercooling. In no small part to the help and participation of this board. I have two radiators in my loop. a 360mm UT60 from OCool (60mm thick, 9 fpi) and a 240mm of the same exact spec. I am currently using super lower rpm (900-1200) enermax silence 120mm's. I have push pull on both rads so a total of 10 fans. After looking at martinsliquidlabs, it appears my rad(s) optimal fan rpm range is no more than 1800 rpm. As in, anything over that will yield little to no gains as far as temps are concerned. Looking around, I have seen the 1850 rpm Scythe gentle typhoons for $14-$15 each. Would these new fans lower temps at least by 3-5C? I don't want to dump almost $200 to find a 1C drop in temps overall. Anyone have experience with these fans? Also, I will be using a 2 way splitter to control 2 fans per channel via my fan controller. 60 watts per channel. Do these fans whine at all when lowering voltage?
Any help would be sincerely appreciated. Included is a pic of my hwmonitor page.
