BUMPING someone else's thread.. thats so nice! Thanks!
Check out the lamptron line of fan controllers.
EDIT: Ok I see why you did that, because you asked a remotely similar question! W00t!
Something along the lines like the FC5V2, looked nice.
Too bad there are no retailers in Norway who has it though, probably have to buy it from Germany or UK.
Looking for a fan controller that has enough watts to handle a high CFM Delta or San Ace fan, has PWM control, and has some kind of display for voltage/RPM.
Can you guys suggest one?
Thanks in advance!
You are correct and its a MONSTER fan.. 38mm (if not the other bigger monster) depth and few k RPMs. Moves MAD amounts of air with mad amounts of noise.
Forgot the link above
Looks like there is nothing that fits what I want, so will have to give up PWM control and just use voltage control. Pretty sure I've settled on the Lamptron Touch. Read a lot of good reviews about it.
http://www.lamptron.com/products/view/Fan_Controller_Touch
Now, I need to find myself a nice, high CFM, high RPM fan that is less than 30w on start up. Suggestions anyone?
