- Feb 22, 2009
Hi OCfriends,
I am on a fence. I have already ordered a Lenovo Y50-70 Laptop - 59440654 for $899.00
4th Generation Intel® CoreTM i7-4720HQ Processor (3.60 GHz Turbo, 2.60GHz Base, 1600MHz 6MB)
1TB + 8GB SSSHD / No Optical Drive
15.6" Full HD 1080p IPS (1920 x 1080) Backlight Display with integrated camera
16GB PC3-12800 DDR3 1600MHz SDRAM SODIMM Memory
NVIDIA GeForce GTX 960M 4GB Graphics Card / Dual Band Wireless-AC
On the other hand, for the exact same money, I could get the baseline 2015 Dell XPS 13.
Both have great specifications and reviews for their respective classes, but since they are so different for needs, I fear I will not make the right decision.
A little bit of history. I have had a netbook, I own a Lenova Yoga 2 10.1", and I had a Dell 15.6" laptop that I gifted to my daughter. It had a T4500 and 4 GB of ram and a 720p screen. I am so underwhelmed by the Yoga 2. Its too small to be productive at all, and the Atom processors are just not fast enough to get out of their own way. I loved my Laptop, but my daughter needed one while I was visiting her in Germany, so I gave her mine with plans to upgrade.
So, the Dell XPS 13 that I am looking at has a i5-5200U Processor, 4 GB Ram and a 13.3-inch FHD (1920 x 1080) InfinityEdge Display, so at a minimum it stacks nicely against what I already had. Benchmarks of the 5200U are well above the T4500 and the Display is more than enough of what I need for regular computer use.
The Lenovo Y50 is overkill for what I need a laptop for. My Main system is top notch and will be for years to come.
My intent. 90% of the use of this laptop would be for the office environment and while traveling. Bang for the Buck, the Lenovo stomps the xps 13 into the ground, however its a matter of what I need vs. getting the most for my money.
Am I crazy for thinking I should just go with the Dell XPS or will I be underwhelmed like with the Netbook and Yoga 2? Please don't tell me I have already made the decision. What I am looking for is someone who has been in the same or similar predicament and whether you have bought one and then gone back to another?
Thanks in advance.
Thanks in advance.
