I don't know where I should put this but I'm desperate. A simple google search brought me to your fine website. We'll start from the beginning.
So I play Skyrim, a lot. Recently I was looking into ways to increase my performance and turned to overclocking. I have an Nvidia GTX 460 Hawx (talon attack, also I was using a Corsair 750w PSU) So I downloaded Afterburner and Nvidia Insepctor, and after much research I slowly started to overclock my card. I carefully monitored my temps, (which never went above 65c on max load) and resumed the day to day excited at my about 10 fps increase.
Few days later, to my great horror, my computer just shuts off. So I go to turn it back on and my fans try to turn for a split second but don't get very far. Also the power light on the front of the case illuminates and then slowly fades. Pushing the power button on the front of the case simply does nothing, although the power button and reset button located on my mobo were still shining brightly.
I don't know what I did wrong, I was so careful. By the end I had my settings like this in Nvidia Inspector:
Core Clock: 880
Memory Clock: 2110
Shader Clock: 1760
Voltage: 1.087
If you're still reading, thank you kind soul. So I panicked and took it to the Geeksquad at Best Buy, and told them the problems I was having. He said it sounded like my PSU so of course he plugged in a different PSU and lo and behold my computer starts up just fine. So I thank him, buy my new PSU and rush home to put it in. (Cause I'm not paying 50$ to have them install it, and installing a PSU is easy.)
After installing my new Corsair 800w I go to turn on my computer and
...same thing as before. Fading light, fans turn halfway, won't start up.
So I take it back and they offer to give me a free 70$ diagnostic to test the other hardware.
That was last night, and it's been there all day today. I called them and they said that the computer still won't start up and they can't really get a handle as to what's going on so it's "probably" a fried motherboard. They also made sure to tell me that the GPU could be fried as well "because that sometimes happens."
In a perfect world I'd like to think that somehow the Geeksquad fried my board but, I probably deserved all of this by being new and inexperienced at overclocking, but any advice or any help at all that someone can give would be very much so appreciated.
Also, if you need more information about my rig, or the situation, just let me know.
Core Clock: 880
Memory Clock: 2110
Shader Clock: 1760
Voltage: 1.087
