- Apr 28, 2002
- Chicago suburbs (Bartlett)
I recently did my first volt mod on my is7-e. I needed more voltage for my new bh6 memory. I did hipro5's ic7 vdimm mod (the resistor is in the same position on the is7). It worked at first and i was able to adjust the voltage. But after 15 minutes the vr broke. While replacing it i hit the 10 ohm resistor and it broke off along with the 2 soldering points. I cant solder the connection back together because the solder doesnt want to stick to the motherboard. Is there any points i can use for soldering that can go around this problem? http://www.xtremesystems.org/forums/showthread.php?postid=212806#post212806
