- Jul 16, 2003
- ALASKA
Help Me build a new system with 2000 Dollars and the pile of hardware on my desk
Help me build a system and get the biggest bang for my $. I am not a fanboy of any particular brand, I like what works well. I last built a system over two years ago and have added a few components since. I purchased an x2 4400 on a whim recently. I was really wanting to upgrade bad since I was in the habit of doing it every 12-18 months before. However things seemed to have slowed down a little in the advancement of overall speed and performance in the past two years.
I’ve got $2000 dollars and want to upgrade. I need your help and experience in building the best system around my current hardware and available funds.
If funds allow I would like a new case something cool and quiet.
I was looking at the Pc Power and cooling 850w SSI PSU do you think it would be overkill, I want plenty of power and stability. I had an issue with a Antec 550 truepower not long ago and had to pull a fan and a hard drive to have enough juice to boot properly.
I like to Overclock, and my Mushkin DDR PC3500 BH5’s will volt high. However, if new DDR is needed for the new system then so be it.
Though I like to overclock, I Like rock solid stability also. So if you know of a good bios and settings for your configuration let me know.
I like to digital paint in Photoshop, do DVD encoding, surf, and what should have been listed first “Game”.
I am not attached to the X2 4400+ and could sell it easily for more than I purchased.
I think I might need some more storage for DVD encoding and back up. However, Power comes first.
I currently have on hand the following hardware:
AMD X2 4400+
Zalman 7000cu
First edition Antec True control 550w PSU
4 x 512 Mushkin PC3500 BH5 @ 2-2-2-5
ATI X800XT PE (AGP)
2 x 74GB Raptors - SATA
2 x 36GB Raptors - SATA
80GB seagate SATA HDD
2 x 120GB WDJB1200 HDD - IDE
Lighton DVD-rom (color – beige)
Plextor 708 DVDR (color – beige)
Lighton CDR (color – beige)
Lian-li PC68 case
NEC FP2141SB 21" CRT (Black)
DELL 2405FPW 24" Wide Screen, 12ms LCD (Black)
Griffin Powermate
Altec Lansing 221 speakers (Black and silver)
Wacom intuos 6x8” drawing tablet
Microsoft internet keyboard (Black)
Intellimouse Explorer 3.0A (Silver and grey
Windows XP HOME
I could sell any of the above on ebay I am not attached to any of it. It’s just hardware to draw from for the new system.
And I can come up with a little more $ if necessary
I usually shop at NEWEGG.COM
Thanks Guys I am curious what you all will come up with!!!
AMD X2 4400+
Zalman 7000cu
ATI X800XT PE (AGP)
Lian-li PC68 case
Griffin Powermate
Windows XP HOME
