I want to piece together a old Intel dual core for my dad which is on a 1.7ghz p4 with 768 of ddr. LOL he usually has like 5 different fire fox windows open with about 3 tabs each so this thing has to go!!!!!
I know nothing about intel what so ever.
Here is what I was looking at
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116391
What motherboard would I need and what ram does this cpu support. Im open to all options just need something faster then a 1.7ghz single core looking for at least a 2.0ghz dual core. And would like for it to have a PCI-E 16x slot for a 450 GTS I have sitting here. But that is not a need.
If some one could give me a theoretical build I could go off of that would be great because I do not know what is compatible since I have no knowledge of intel.
Things I have for the build
Full tower case
550w PSU with 20+4 and 4 pin cpu
350gb 7200rpm IDE HDD
This will be running windows xp 32bit
Other then that im open to all options. Just wanted to do a Intel build for the heck of it.
Thanks all for the help,
Shadow
Full tower case
Shadow
