what 19 lcd Monitor for under $500 would be best for a all around use including games like UT2k3 or is there a 18.1 for less that would be a better choice.
Here are the two lcds I am choosing from
"NEC 19" LCD AccuSync LCD9V"
Active Display Area:
Horizontal: 14.8 inches / 376.3 mm
Vertical: 11.9 inches / 301 mm
(Dependent upon signal timing used)
Contents of Packaging
User's manual, Power cord, Signal Cable, Setup Sheet, LiquidView brochure
Current Rating:
0.9 A @ 100 - 120 V / 0.5 A @ 220 - 240 V
Dimensions:
Net (with stand):
16.5 in. (W) x 16.4-21.1 in. (H) x 9.1 in. (D)
418 mm (W) x 417-537 mm (H) x 230.5 mm (D)
Net (without stand):
16.5 in. (W) x 14.4 in. (H) x 2.6 in. (D)
418 mm (W) x 367 mm (H) x 67 mm (D)
Gross:
20.2 in. (W) x 20.9 in. (H) x 11.2 in. (D)
512 mm (W) x 530 mm (H) x 285 mm (D)
Display Colors:
over 16,000,000 Colors
(Dependent upon display card used)
Height Adjustment:
3.7 in / 120mm
Input Video Signal:
ANALOG: 0.7 Vp-p/75 Ohms Positives
LCD Module:
19-inch (19" viewable image size), active matrix, thin film transistor (TFT), liquid crystal display (LCD), 0.294 mm dot pitch, 250 cd/m² white luminance - typical, 500:1 contrast ratio - typical, 25ms response time
Limited Warranty:
3 Years Parts and Labor, including Backlight
Operating:
Temperature: 5°C to 35°C / 41°F to 95°F
Humidity: 30% to 80%
Altitude: 3,000 m / 10,000 Feet
Recommended Resolution:
1280 x 1024 @ 60 Hz
Regulatory Approvals:
UL/C-UL or CSA, TUV/GS, Energy Star, CE, FCC Class B/Canadian DOC, TUV/Ergonomie, Windows XP, MPRII / MPRIII
Resolutions Supported:
720 x 400* at 70 Hz
640 x 480* at 60 Hz to 75 Hz
800 x 600* at 56 Hz to 75 Hz
832 x 624* at 75 Hz
1024 x 768 at 60 Hz to 75 Hz
1152 x 864 at 75 Hz
1280 x 1024 at 60 Hz to 75 Hz
NOTE: Some systems may not support all modes listed.
Signal Cable:
15 pin D-SUB
Storage:
Temperature: -10°C to +60°C / 14°F to 140°F
Humidity: 10% to 85%
Altitude: 9,144 m / 30,000 Feet
Sync:
Seperate sync: TTL Level
Horizontal sync: Positve/Negative
Vertical sync: Positive/Negative
Synchronization Range (Automatic):
Horizontal: 31.5 kHz to 81.0 kHz
Vertical: 56.0 Hz to 75.0 Hz
Tilt / Swivel:
Swivel: 90° (Left/Right: 45°)
Tilt: Up: 30° / Down: -5°
VESA Hole Configuration Spec.
100mm x 100mm
Viewing Angle:
Vertical: 170° (Left/Right: 85°)
Horizontal: 170° (Up/Down: 85°)
Weight:
Net: 16.1 lbs. / 7.3 kg
Net (without stand): 10.8 lbs. / 4.9 kg
Shipping: 20.9 lbs. / 9.5 kg
** Disclosures **
* LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendors and is not specific to any one vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
* 19-Inch to 21-Inch:
* Total Defects: 8
* Bright or Dark Dots (random): 4
* Bright or Dark Dots (2 adjacent): 2
* Bright or Dark Dots (3 adjacent): 0
* Minimum distance between defects: 15mm
(bright to bright dots); 5mm (dark to dark dots)
And my other choice is
"Samsung 191T 19 inch LCD Monitor Silver w/DVI"
SPECIFICATIONS
PANEL Type a-si TFT/PVA
Size 19"
Pixel Pitch (mm) 0.294
Brightness (cd/m2) 250 cd/m2
Contrast Ratio 500:1
Viewing Angle 170 / 170
Interface Analog/Digital
FREQUENCY Horiz. Rate (Analog) 30-81
Horiz. Rate (Digital) 30-63
Vertical Rate 58-85
Bandwidth 135 MHz
RESOLUTION Maximum (Analog) 1280 x 1024
Maximum (Digital) 1280 x 1024
Native 1280 x 1024
COLOR Maximum 16.7 M
SIGNAL INPUT Input Video Signal Analog RGB, DVI Digital link
Video Level: Analog 0.7VP-P
Video Level: Digital TMDSTM
Sync Type Separate H/V, Composite H/V, SOG
Input Connectors 15pin D-sub, DVI-D
PLUG & PLAY DDC DDC 2B
POWER On/Working 41 Watts (Max)
WALL MOUNT VESA® 100mm
REGULATIONS Safety UL 1950, CE, CSA, TUV, IEC 950, NEMKO
EMI/Emissions FCC, DOC, CISPR22, EMI, EN500821, VCCI
Emission Standard TCO '99
CABINET COLOR Front/Back Black
DIMENSIONS Physical (WxHxD) 16.4" x 17.7" x 8.2"
Packaging (WxHxD) 20.3" x 21.1" x 11.3"
WEIGHT Net(Physical) 13.0 lbs.
Gross (packaging) 18.5 lbs.
FEATURES Dual CPU input (analog/digital) & auto signal detection, 0.7" bezel width, Pivot Technology (and software included).
INCLUDED n/a
OPTIONAL n/a
WARRANTY Parts/Labor/Backlight 3 / 3 / 3
I plan on usin one of these with a 9800 AIW pro
Thanks!!!!!!
Current Rating:
Dimensions:
Net (with stand):
Gross:
Display Colors:
Height Adjustment:
3.7 in / 120mm
Input Video Signal:
LCD Module:
Limited Warranty:
Operating:
1280 x 1024 @ 60 Hz
720 x 400* at 70 Hz
832 x 624* at 75 Hz
1152 x 864 at 75 Hz
Signal Cable:
15 pin D-SUB
Storage:
Sync:
Tilt / Swivel:
100mm x 100mm
Viewing Angle:
Weight:
** Disclosures **
* Total Defects: 8
SPECIFICATIONS
Size 19"
Vertical Rate 58-85
Bandwidth 135 MHz
Native 1280 x 1024
INCLUDED n/a
OPTIONAL n/a
Thanks!!!!!!
