I am trying to understand how to determine which of two different (hypothetical) RAM chips are the fastest. My understanding so far is that the real speed of a RAM is mostly a function of the clock speed (bandwidth) and the CAS latency. From what I have read, a chip with a CAS of 10 and clock of 400 MHz. will perform at the same total speed as a chip with a CAS of 5 and a clock of 200 MHz. Correct?
If so, then why make the change from DDR2 to DDR3 for middle-grade chips like the Sandy Bridge? If the Corei5 can only handle DDR3-1333, then wouldn't it make more sense to go with a DDR2 chip at 1066MHz and CAS 5 then a DDR3 chip at 1333MHz. and CAS 7?
That brings me to my next question. I am considering buying a Corei5 and I am trying to determine what RAM to get. If a Corei5 memory controller cannot control RAM faster than 1,333MHz, then why are there LGA1155 mobos that can run 2,400 MHz RAM?
