- Dec 20, 2001
Allow me to explain my problem. First off I upgraded my MB from an ASUS A7V266-e to an Epox 8kha+ (big mistake on my part) and a new XP 1600+ from my 1500+ I ended up with getting a AGOIA that I have had stable at 10.5x172 but its just been to hot. I also had my AGKGA 1500+ at 10x166 which was pretty good for that chip. I ran 3dmark on the Asus with the 1500+ at 10x166 with windows 2000 and I recieved the highest score yet 97xx. I then switched to the Epox with the 1600+ that I am not running at 10.5x167 so the chip is a good deal faster, but my scores are 500 points lower. I am also running windows XP on the Epox which should yield better scores. Both systems were running the newest catlyist drivers (not the betas) and I was using Rage3d Tweaker for both systems set to 280/275 on my 8500le. I have come to the conclusion that my Epox while a better o/c board sucks for multimedia. Also my sandra scores are lower for the Epox. I cannot figure it out, but Im wishing that I still had my ASUS. All the settings on the two systems were identical execpt for the differences that I described to you. Check out my compare links for the info.
ASUS
Epox
ASUS
Epox
