Well its all in the chip itself for as high as you can go, ah and also the motherboard
The best you can do it pick up a nice HSF (Glaciator, CAK38 ect.), and try increasing the FSB in 1 or 2MHz increments (if you can with your mobo), and push it down to your last option that works when you start getting lockups, and dont forget to watch your temps!
If u have ur motherboards instruction manual, might be a good idea to take a look in it. I have a PIII1Ghz and the only way i could o/c it was to bump up the FSB via my motherboard, not the bios...
