CASE:
Cooler Master Wave Master Case without Power Supply
LINK: http://www.newegg.com/app/viewproduct.asp?description=11-119-023
OR
Cooler Master Cavalier 3 Silver/Blue ATX Mid-Tower Case With Side Window
LINK: http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-058&depa=1
(scroll to the bottom for computer specs)
For the PSU would you recommend staying with the one the Cavalier comes with or should I change it?
PSU: any other psu that you think is good please post
Antec 480W Power Supply with Blue LED Fan
LINK: http://www.newegg.com/app/viewproduct.asp?description=17-103-914
or
Thermaltake Silent PurePower, 420W ATX power supply.UL, CSA, TUV, CE Approved. Intel Pentium 4 Compliant
LINK: http://www.newegg.com/app/viewproductdesc.asp?description=17-153-006&DEPA=0
or
Antec 430W Power Supply, Model "TRUE430"
LINK: http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-908&depa=0
Computer specs:
OR
or
or
Computer specs:
Code:
1x Xper Aluminum Hard Drive Cooler with two 60mm Cooling Fan, SILVER
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=11-999-034[/url]
2x CoolerMaster Blue 80mm Neon LED Fan
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=11-999-051[/url]
1x COOLER MASTER Round, 18-Inch, Floppy drive cable, Booted, 2-Connector
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=12-103-302[/url]
2x COOLER MASTER ROUND, 18-Inch, ATA133/100/66 IDE Cable
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=12-104-225[/url]
1x ABIT "IC7-G MAXII ADVANCE" i875P Chipset Motherboard for Intel Socket 478 CPU
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=13-127-152[/url]
1x BFG nVIDIA GeForce 6800 Video Card, 128MB DDR, 256-Bit, TV-Out/DVI, 8X AGP
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=14-143-020[/url]
1x Intel Pentium 4/ 3.2 GHz 800MHz FSB, 512K Cache, Hyper Threading Technology
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=19-116-165[/url]
2x Geil Value Series 184 Pin 512MB DDR PC-3200
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=20-144-305[/url]
1x NEC 1.44MB Black Internal Floppy Drive
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=21-152-005[/url]
1x Western Digital Raptor 36.7GB 10,000RPM SATA Hard Drive, Model WD360GD
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=22-144-200[/url]
1x Logitech Elite Keyboard USB/ PS/2 104keys
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=23-126-114[/url]
1x Logitech Blue Performance Optical Mouse PS2/ USB
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=26-104-151[/url]
1x Lite-On Black 16X DVD-ROM, Model SOHD-167T
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=27-131-118[/url]
1x NEC 16X Double Layer DVD±RW Drive, Black
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=27-152-032[/url]
1x Creative Labs Sound Blaster Audigy2 ZS Platinum PCI Sound Card
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=29-102-163[/url]
1x Arctic Silver Premium Silver Polysynthetic Silver Thermal Compound
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=35-100-007[/url]
1x Cooler Master JET 4 CPU FAN for Intel P4 478
LINK: [url]http://www.newegg.com/app/viewproduct.asp?description=35-103-142[/url]
